Postgres folder too big
Hi all,
my folder:
/var/lib/postrgesql/9.6/main/base/16443 is about 11gb…
Under server.properties I see:
enable.db=true
enable.raw.db.data.store=true
So I guess that I have enable raw data on server…
Now, I can disable this and get free space?
After disabled, what will I lost?
Many thanks
I guess the first question is what version of local server are you running?
Quite old then.
I guess that it’s a question for @Dmytro, but as Legacy local server is no longer supported I’m not sure if you’ll get an answer.
But, if I set:
enable.db=false
enable.raw.db.data.store=false
I suppose that the DB stops to increase…
no problem if i lost my data, but everything must work!
thanks
