Последствия блокировки Telegram
Скажите, есть какие то новости по разблокировке ваших IP? Установить локальный сервер по инструкциям с Github невозможно.
В этом месте
wget “https://github.com/blynkkk/blynk-server/releases/download/v0.35.1/server-0.35.1-java8.jar
терминал выдает следующее:
–2018-04-22 10:10:21-- https://github.com/blynkkk/blynk-server/releases/download/v0.35.1/server-0.35.1-java8.jar
Resolving github.com (github.com)… 192.30.253.112, 192.30.253.113
Connecting to github.com (github.com)|192.30.253.112|:443… connected.
HTTP request sent, awaiting response… 302 Found
Location: https://github-production-release-asset-2e65be.s3.amazonaws.com/32753016/cd97c36c-43f6-11e8-817b-709db8f2c6bb?X-Amz-Algorithm=AWS4-HMAC-SHA256&X-Amz-Credential=AKIAIWNJYAX4CSVEH53A%2F20180422%2Fus-east-1%2Fs3%2Faws4_request&X-Amz-Date=20180422T101021Z&X-Amz-Expires=300&X-Amz-Signature=cbf94849883b471b35dbed76cd80a50a44ab775f5bba752b6dc50e870d414d8f&X-Amz-SignedHeaders=host&actor_id=0&response-content-disposition=attachment%3B%20filename%3Dserver-0.35.1-java8.jar&response-content-type=application%2Foctet-stream [following]
–2018-04-22 10:10:21-- https://github-production-release-asset-2e65be.s3.amazonaws.com/32753016/cd97c36c-43f6-11e8-817b-709db8f2c6bb?X-Amz-Algorithm=AWS4-HMAC-SHA256&X-Amz-Credential=AKIAIWNJYAX4CSVEH53A%2F20180422%2Fus-east-1%2Fs3%2Faws4_request&X-Amz-Date=20180422T101021Z&X-Amz-Expires=300&X-Amz-Signature=cbf94849883b471b35dbed76cd80a50a44ab775f5bba752b6dc50e870d414d8f&X-Amz-SignedHeaders=host&actor_id=0&response-content-disposition=attachment%3B%20filename%3Dserver-0.35.1-java8.jar&response-content-type=application%2Foctet-stream
Resolving github-production-release-asset-2e65be.s3.amazonaws.com (github-production-release-asset-2e65be.s3.amazonaws.com)… 52.216.134.19
Connecting to github-production-release-asset-2e65be.s3.amazonaws.com (github-production-release-asset-2e65be.s3.amazonaws.com)|52.216.134.19|:443… failed: Connection timed out.
Retrying.
Ксожалению VPN на моем Raspberry Pi не установлен. Может быть подскажете какой установить?
Спасибо!
Выложил на гугл драйв - https://drive.google.com/file/d/1nijzNIadbnk11xLSP1Hsc6Xpj6KxrZeF/view?usp=sharing
Если используете хром или фаерфокс, поставьте Browsec и все будет качаться.
Спасибо.Попробую.
AddIn для браузера или отдельное приложение?
VPN AddIns пробовал для firefox Raspbian нужен 55 версии. У меня 52. Дальше не разбирался.
Все слишком вынужденно быстро приходится осваивать. Хочется надеяться что начнут разблокировку в ближайшее время.
help.blynk.cc тоже не работает без VPN…
А Телеграм работает как работал…
Телеграм рыссылает айпи серверов через пуш-нотификейшены. То есть по факту - новые адресса серверов приходят от вполне себе “законных” серверов епла и гугла. РКН судя по всему не решается их забанить, иначе ляжет почти весь мобайл :slight_smile:. Поэтому РКН блочит подсети провайдеров, в которых разворачивают телеграм.
И как дальше жить? Ничего не работает второй день…
Esp32
скачайте исходник сервера по ссылке выше и запустите локально. На железках нужно будет одну строку поменять + токен заменить.
Вот тут инструкция по-русски
Спасибо!
При создании нового проекта появляется сообщение что токен отправлен, но ничего не указанный email не приходит. В свойствах проекта нажимаю E-mail token, после чего возникает вот это сообщение. Через VPN точно так же. Почему Later? Все же есть какая то непреодолимая причина, и почта тоже идет через заблокированные серверы?
Если так, опубликуйте их IP& чтобы каждый заинтресованный мог отослать эти адреса в РКН сам?
@iGonch почту на локальном сервере настраивали?
Можно нажать на сам токен и он скопируется в буфер. После этого можно отправить себе через имейл клиент
Спасибо.
Вот здесь все нашел в итоге.
Если я правильно понял, это раздел Enable Mail on local serve Где указано что разрешены только адреса gmail которые как раз и подверглись блокировкам… Даже если смогу скопировать токен, как пишет ниже Павел, получать уведомления на почту я не смогу?
Если несложно, поместите раздел Enable Mail on local server выше Quick local server setup on Raspberry PI. В кликабельном виде он почти в самом низу, хотя на странице он сразу перед инструкцией для RPi.
Павел, спасибо. Gmail после создания mail.properties, принимает и отсылает почту, несмотря на то что в браузере недоступен. Иэнтересно как долго это проработает…
Как вы расцениваете перспективы по разблокировке ваших IP? РКН ответил хоть что то? Может вы опубликуете список адресов, чтобы пользователи сами завалили РКН запросами по разблокировке? Локальный сервер конечно здорово, но с ним вы не ничего не заработаете…
Спасибо. Пофиксили.
Думаю, со временем РКН разблочит подсети провайдеров, как только телеграм удалят из сторов.
Нет. Глухо.
139.59.206.133, 46.101.143.225.
Мы зарабатываем на бизнес подписках, а не на облаке. Так что мы ничего не теряем. Не переживайте :wink:.
Я решил проблему тем, что включил впн на самом роутере, к которому подключаются устройства. Протоколы PPTP или L2TP есть наверное в каждом роутере.
Я не совсем понимаю пользу от запуска локального сервера если мне нужен доступ с мобилы на работе к устройствам дома через другого провайдера и без белого IP.
Сейчас ситуация такая, мобила соединяется с сервером Blynk только через мобильный интернет от МТС. Видимо, пока. По WiFi от YOTA и WiFi от Onlime - блокируется.
Перепробовал кучу проксей для android вплоть до FreeOpenVPN, не помогает.
В тоже время со стороны девайсов(ESP8266, ESP32) через тех же провайдеров блокировки нет, вот что не понятно.
В этой ситуации конечно толку нет. Дмитрий написал IPs которые подлежат разблокировке. Напишите на адреса указанные здесь https://rkn.gov.ru/news/rsoc/news56980.htm
Может разблокируют быстрее, если писать много и часто… впрочем, пока никак не реагируют.
Да написал уже и заклеймил их позором
Может я что-то не понимаю, но ваша мобила будет стучаться на ваш локальный сервер из любой точки мира (если порты пробросите)
Ну да, но этого мало, нужен белый IP, ибо, под Win 10 vpn на ddns не работает, имхо.
Одним словом, тот еще гимор.
Так а зачем вам VPN в данном случае?
Схема: Blynk app <-internet-> modem/router <-> Local Blynk Server <-> Device
