• Adafruit Bluefruit 32u4 + Adafruit Stemma Soil Sensor
• Using Blynk for IOS latest version (Not-beta)
• Latest Blynk Library
I have verified that the Bluefruit and the Stemma soil sensor work. I am able to connect to the Bluefruit using the Blynk App and write to Virtual Pins if I just send millis(), as in the example or if I even send data from a DHT-11; however, as soon as I try to poll data from an Adafruit Stemma Soil Sensor and virtual write the data, it seems to break the project and I receive no data in the app. It seems that as soon as I introduce the code polling the soil sensor, even trying to virtual write millis() ceases to work. I had the same issue with an Arduino Uno and a HM-10 bluetooth module. I don’t know if it is because the Stemma Sensor uses SDA and SCL pins or what, but it is rather odd. Any help would be appreciated.
//#define BLYNK_PRINT Serial
#include <Adafruit_BLE.h>
#include <Adafruit_BluefruitLE_SPI.h>
#include "Adafruit_seesaw.h"
Adafruit_seesaw SoilSensor;
char auth[] = "XXXXXXX";
// SHARED SPI SETTINGS (see adafruit webpages for details)
#define BLUEFRUIT_SPI_CS 8
#define BLUEFRUIT_SPI_IRQ 7
#define BLUEFRUIT_SPI_RST -1 // Optional but recommended, set to -1 if unused
#define BLUEFRUIT_VERBOSE_MODE true
// Create ble instance, see pinouts above
Adafruit_BluefruitLE_SPI ble(BLUEFRUIT_SPI_CS, BLUEFRUIT_SPI_IRQ, BLUEFRUIT_SPI_RST);
void myTimerEvent(){
float capc = map(SoilSensor.touchRead(0), 0, 1016, 0, 100);
float temp = ((SoilSensor.getTemp())*1.8) + 32;
if (isnan(h) || isnan(t)) {
Serial.println("Failed to read from Stemma Soil sensor!");
return;
Blynk.virtualWrite(V5, temp);
Blynk.virtualWrite(V3, capc);
ble.begin(BLUEFRUIT_VERBOSE_MODE);
ble.factoryReset(); // Optional
ble.setMode(BLUEFRUIT_MODE_DATA);
Blynk.begin(auth, ble);
