On Blynk2 PLUS 10 users I sent an invite which confirmed. However, when logging in, you cannot access the device and also do not have access to the rules.
That will be because you’ve chosen the “user” role, which doesn’t have access to devices.
You need to give these users either the “staff” or “admin” role.
This is the answer, however in a similar post @Pavlo mentioned this might actually be a glitch or issue with the “user” role because as things are currently setup, there is no actual function or purpose to “users” only staff.
And unfortunately staff can see ALL your devices, not just the ones they are assigned ownership of.
I think from the conversation on my post the answer is that one of the devs is going to take a look at it at some point and hopefully the lack of usefulness of users is rectified.
