Before creating the topic
- Search forum for similar topics
- Check http://docs.blynk.cc and http://help.blynk.cc/
- Add details :
• Blynk Library version
• Add your sketch code.
Code should be formatted as example below.
//Include the library files
#include <Wire.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
#define sensor 33
#define relay 4
//Initialize the LCD display
LiquidCrystal_I2C lcd(0x27, 16, 2);
// Enter your Auth token
char auth[] = "*****";
//Enter your WIFI SSID and password
char ssid[] = "****";
char pass[] = "*******";
Blynk.begin(auth, ssid, pass, "blynk.cloud", 80);
lcd.init();
lcd.backlight();
pinMode(relay, OUTPUT);
digitalWrite(relay, HIGH);
lcd.setCursor(1, 0);
lcd.print("System Loading");
for (int a = 0; a <= 15; a++) {
lcd.setCursor(a, 1);
lcd.print(".");
delay(200);
lcd.clear();
//Get the ultrasonic sensor values
void soilMoisture() {
int value = analogRead(sensor);
value = map(value, 0, 4095, 0, 100);
value = (value - 100) * -1;
Blynk.virtualWrite(V0, value);
Serial.println(value);
lcd.setCursor(0, 0);
lcd.print("Moisture :");
lcd.print(value);
lcd.print(" ");
//Get the button value
BLYNK_WRITE(V1) {
bool Relay = param.asInt();
if (Relay == 1) {
digitalWrite(relay, LOW);
lcd.setCursor(0, 1);
lcd.print("Motor is ON ");
lcd.print("Motor is OFF");
void loop(){
soilMoisture();
Blynk.run();//Run the Blynk library
delay(200);
