Please help me with code error with Blynk.begin(auth,ssid, pass);
#define BLYNK_DEBUG
#include <Ethernet.h>
#include <DHT.h>
#define DHTPIN 2
#define DHTTYPE DHT11
DHT dht(DHTPIN, DHTTYPE);
char auth[] = "a94be1f3b38b46ed8ca65f8e74f96055";
char ssid[] = "Motel Trang";
char pass[] = "nhanghitrang257";
WidgetLED led1(0);
WidgetLED led2(1);
WidgetLED led3(2);
WidgetLED led4(3);
int ChkOutputStateLed1 = 0;
int ChkOutputStateLed2 = 0;
int ChkOutputStateLed3 = 0;
int ChkOutputStateLed4 = 0;
  Serial.begin(112500);
  dht.begin();
  timer.setInterval(10, sendDHT);
  pinMode(14, OUTPUT);
  pinMode(12, OUTPUT);
  pinMode(13, OUTPUT);
  pinMode(15, OUTPUT);
  digitalWrite(14, LOW);  // active High
  digitalWrite(12, LOW);  // active High
  digitalWrite(13, LOW);  // active High
  digitalWrite(15, LOW);  // active High
  while(Blynk.connect()==false){}
void sendDHT()
  float h = dht.readHumidity();
  if (isnan(h) || isnan(t)) {
    return;
  Blynk.virtualWrite(V4, t);
  Blynk.virtualWrite(V5, h);
void LEDLastStatus()    // LED Last status to display the status when Mobile App is started
  ChkOutputStateLed1 = digitalRead(14);   // reading  output pin 14
  ChkOutputStateLed2 = digitalRead(12);   // reading  output pin 12
  ChkOutputStateLed3 = digitalRead(13);   // reading  output pin 13
  ChkOutputStateLed4 = digitalRead(15);   // reading  output pin 15
  if (ChkOutputStateLed1 == HIGH){led1.on();} else{led1.off();}   // actice high
  if (ChkOutputStateLed2 == HIGH){led2.on();} else{led2.off();}   // actice high
  if (ChkOutputStateLed3 == HIGH){led3.on();} else{led3.off();}   // actice high
  if (ChkOutputStateLed4 == HIGH){led4.on();} else{led4.off();}   // actice high
BLYNK_WRITE(0)  // virtual pin0 control on App
  if (param.asInt()) {
    digitalWrite(14, LOW);   // control  D5 PIN14 NodeMCU
    led1.off();
    digitalWrite(14, HIGH);
    led1.on();
BLYNK_WRITE(1)  // virtual pin1 control on App
    digitalWrite(12, LOW);   // control  D6 PIN12
    led2.off();
    digitalWrite(12, HIGH);
    led2.on();
BLYNK_WRITE(2)  // virtual pin2 control on App
    digitalWrite(13, LOW);   // control  D7 PIN13
    led3.off();
    digitalWrite(13, HIGH);
    led3.on();
BLYNK_WRITE(3)  // virtual pin3 control on App
    digitalWrite(15, LOW);   // control  D8 PIN15
    led4.off();
    digitalWrite(15, HIGH);
    led4.on();
  LEDLastStatus();
Hi. You can’t call this in a loop as this creates Introduction - Blynk Documentation
thank you so much
i do it
