Hello all,
I am having a very frustrating time with my ESP32 (ESP32_Core_Board_V2). I got the esp from hackerboxes. I am also not sure if this is a NodeMCU or an ESP or they go by the same term??? The top of the chip says “ESP-WROOM-32”. I am also fairly new to arduino although being an IT Major, this is still complicated for me. When i try and upload the “Blink” sketch from the examples menu to verify my board is functional, i get this message:
warning: espcomm_send_command: didn’t receive command response
warning: espcomm_send_command(FLASH_DOWNLOAD_BEGIN) failed
error: espcomm_upload_mem failed
Here is the screenshot of my board settings, i am also using Windows 10:
I want to note i have tried >>>> EVERYTHING:
-checked and changed cable NUMEROUS times
-Uninstalled and reinstalled the chip driver, Arduino IDE, Libraries, Board Configurations in board manager(Also tried different versions)
-I have 2 ESP’s and i get the same error on BOTH
-Tried different upload speeds
-Tried selecting different board types
-Tried every Programmer in the “Programmer” menu under “Tools”
-Tried connecting pin IO0 to GND with jumper
-Tried connecting pin IO0 to GND with resistor
-Tried rebooting my computer
There is also NO working solution for me on the internet anywhere, i have searched to the ends of the earth for weeks and have made absolutely no progress towards a solution. As a last result i am posting here to hopefully see a successful solution i can learn from without having to buy a brand new ESP. I would greatly appreciate any and all help.
The Verbose output for the error message is as follows:
Arduino: 1.8.8 (Windows 10), Board: "NodeMCU 1.0 (ESP-12E Module), 80 MHz, Flash, Disabled, 4M (no SPIFFS), v2 Lower Memory, Disabled, None, Only Sketch, 115200"
Build options changed, rebuilding all
Sketch uses 258604 bytes (24%) of program storage space. Maximum is 1044464 bytes.
Global variables use 26696 bytes (32%) of dynamic memory, leaving 55224 bytes for local variables. Maximum is 81920 bytes.
C:\Users\Justin\AppData\Local\Arduino15\packages\esp8266\tools\esptool\2.5.0-3-20ed2b9/esptool.exe -vv -cd nodemcu -cb 115200 -cp COM1 -ca 0x00000 -cf
C:\Users\Justin\AppData\Local\Temp\arduino_build_360047/Blink.ino.bin
esptool v0.4.13-1-gf80ae31 - (c) 2014 Ch. Klippel <ck@atelier-klippel.de>
setting board to nodemcu
setting baudrate from 115200 to 115200
setting port from COM1 to COM1
setting address from 0x00000000 to 0x00000000
espcomm_upload_file
espcomm_upload_mem
setting serial port timeouts to 1000 ms
opening bootloader
An error occurred while uploading the sketch
resetting board
trying to connect
flush start
setting serial port timeouts to 1 ms
flush complete
espcomm_send_command: sending command header
espcomm_send_command: sending command payload
read 0, requested 1
trying to connect
flush start
flush complete
read 0, requested 1
trying to connect
flush start
flush complete
espcomm_send_command: receiving 4 bytes of data
resetting board
trying to connect
flush start
flush complete
read 0, requested 1
trying to connect
flush start
flush complete
trying to connect
flush start
flush complete
Uploading 262752 bytes from C:\Users\Justin\AppData\Local\Temp\arduino_build_360047/Blink.ino.bin to flash at 0x00000000
erasing flash
size: 040260 address: 000000
first_sector_index: 0
total_sector_count: 65
head_sector_count: 16
adjusted_sector_count: 49
erase_size: 031000
setting serial port timeouts to 15000 ms
read 0, requested 1
warning: espcomm_send_command: didn't receive command response
closing bootloader
flush start
flush complete
