Hi guys. I get a ‘pinValue’ was not declaed in this scope’ error when trying to compile the below code. I am new to this, and might have done lots of things wrong, so please bear with me. I am using a Wemos D1 board (ESP8266 Wifi) and using the Blynk server. Library version is v0.5.4
Thank you very much
#include <Servo.h>
Servo myservo; // create servo object to control a servo
int pos= 0; // variable to store the servo position
char auth[] = "c69a278c02814112bf20f7f4f9318ac9";
BlynkTimer timer; // Create a Timer object called "timer"!
char ssid[] = "Legere";
char pass[] = "5596226781";
// in Blynk app write values to the Virtual Pin V1
BLYNK_WRITE(V1)
pinMode(4, OUTPUT);
myservo.attach(5); // attaches the servo on pin 5 to the servo object
if (pinValue == "1") {
digitalWrite(4,HIGH); //switches external led on
for(pos = 0; pos < 180; pos += 4) // goes from 0 degrees to 180 degrees
// in steps of 4 degrees
myservo.write(pos); // tell servo to go to position in variable 'pos'
else {
digitalWrite(4, LOW); //switches external led off
for(pos = 180; pos>=1; pos-=4) // goes from 180 degrees to 0 degrees
