Hello everyone,
I have programmed a push button to operate a relay. No problem.
I would like to add a led that works with the relay, to see if it is open or closed.
Could you help me with the programming because the led won’t light up.
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
#include <Wire.h>
char auth[] = "xxxxxx";
char ssid[] = "xxxxx";
char pass[] = "xxxxx";
// Set your LED and physical button pins here
const int relais1 = 18;
const int btnPin = 19;
const int ledBleu = 34;
void checkPhysicalButton();
int relais1Sate = LOW;
int btnState = HIGH;
int ledBleuState = LOW;
// Every time we connect to the cloud...
BLYNK_CONNECTED() {
Blynk.syncVirtual(V2);
// Alternatively, you could override server state using:
//Blynk.virtualWrite(V2, ledState);
// When App button is pushed - switch the state
BLYNK_WRITE(V2) {
relais1Sate = param.asInt();
digitalWrite(relais1, relais1Sate);
ledBleuState = param.asInt();
digitalWrite(ledBleu,ledBleuState);
if (digitalRead(btnPin) == LOW) {
if (btnState != LOW) {
// Toggle LED state
relais1Sate = !relais1Sate;
ledBleuState =!ledBleuState;
digitalWrite(ledBleu, ledBleuState);
// Update Button Widget
Blynk.virtualWrite(V2, relais1Sate);
Blynk.virtualWrite(V2, ledBleuState);
btnState = LOW;
btnState = HIGH;
pinMode(relais1, OUTPUT);
pinMode(btnPin, INPUT_PULLUP);
pinMode(ledBleu, OUTPUT);
timer.setInterval(100L, checkPhysicalButton);
LED widgets operate on a scale of brightness from 0 (off) to 255 (fully on).
128 will light the LED widget at half brightness. 1 will light the LED so dimly that it appears to be off.
This:
writes either a 0 or a 1 to the LED widget, so it appears to be off all of the time (although if you look very carefully you should be able to see it glow very faintly when you turn the relay on.
The solution is to add 254 to the value you write to the LED widget. 0+254 = 0, 1+254 = 255…
thank you for your answer, the synchronization works perfectly.
If I lose my internet connection, the push button does not work, is there a way to solve this problem
#include <WiFi.h>
#include <Wire.h>
char auth[] = "xxxx";
char ssid[] = "xxxx";
char pass[] = "xxxx";
const int ledBleu = 5;
BLYNK_CONNECTED() {
BLYNK_WRITE(V2) {
// Toggle LED state
btnState = LOW;
btnState = HIGH;
// to avoid delay() function!
You should switch to setting-up your own WiFi connection and if this is successful then using Blynk.config and Blynk.begin to establish the connection to the Blynk server.
Search the forum and you’ll find plenty of examples.
what do you think of this code?
When starting my esp32 my relay jumps twice before stabilizing.
#include <WiFi.h>
#include <Wire.h>
char pass[] = "xxx";
BLYNK_CONNECTED() {
BLYNK_WRITE(V2) {
// Toggle LED state
ledBleuState = !ledBleuState;
btnState = LOW;
btnState = HIGH;
// Setup a function to be called every 100 ms
my push button works fine, with or without connection.
But my Widget button on the application no longer works, why is you ??
#include <WiFi.h>
#include <Wire.h>
char ssid[] = "SFR_6188";
char pass[] = "xxxxxx";
// Toggle LED state
btnState = LOW;
btnState = HIGH;
WiFi.begin(ssid, pass);
//timer.setInterval(3000L, checkBlynk); // check if connected to Blynk server every 3 seconds
Blynk.config(auth);
Thanks a lot for your help. Now that everything works perfectly, on this code I add the code of my 3 ds18B20 to connect in onewire.
This code works well separately but when I combine it with my relay code, the temperature does not appear in the application
#include <WiFi.h>
#include <OneWire.h>
#include <Wire.h>
char auth[] = "xxxxx";
// one wire temperature
#define ONE_WIRE_BUS 23
int deviceCount = 0;
float tempC;
void temperature();
BLYNK_WRITE(V2) {
void temperature()
// Send command to all the sensors for temperature conversion
// Display temperature from each sensor
for (int i = 0; i < deviceCount; i++)
tempC = sensors.getTempCByIndex(i);
Blynk.virtualWrite(i+21,tempC);
// Toggle LED state
btnState = LOW;
btnState = HIGH;
sensors.begin(); // debut de la librairie capteur de température
Blynk.config(auth);
timer.setInterval(10000L, temperature);
