Physical switch to control a virtual button?
Hi, I have a working garage door opener with the Blynk. I’m planning to make a fingerprint reader next to my garage door, which would open the door. Is it possible to make so that the physical switch is synced to another Blynk project? The fingerprint sensor will be powered by solar panel, so its an another esp than the garage door opener.
Could I make it with same project auth, or something else?
You need to use the Bridge Widget http://docs.blynk.cc/#widgets-other-bridge
