I used blynk with my particle photon.
First, I accidentally chose my hardware as “particle core” but it works. (I made a lot of project)
Then I use particle official android app to make some test about my project.
When I returned to blynk app I realized and changed hardware as “particle photon” but it didn’t work i also try “core” but it didn’t work either.
I tried different codes and tokens. Any help ?
One of my code is here:
#include "blynk/blynk.h"
char auth[] = "my_auth_token";
Blynk.begin(auth);
pinMode(D7, OUTPUT);
I know, I flashed ( after tinker) different codes and i tried different tokens but it didn’t work.
When i run project on blynk app. Blynk app shows me an error “your particle photon was disconnected” during reflashing my blynk code to photon. (because photon restart itself when flashing).
So i think there is no problem connection between blynk and photon but somehow widgets didn’t work (i tried different pins and widgets too).
Since everything is working for everyone else, I can only recommend deleting and reinstalling the app, creating a new Project and generate a new token.
Also, post your code here. Maybe the problem is there.
Your code doesn’t look like an example sketch we provide…
* Downloads, docs, tutorials: http://www.blynk.cc
* Blynk community: http://community.blynk.cc
* Social groups: http://www.fb.com/blynkapp
* http://twitter.com/blynk_app
//#define BLYNK_DEBUG // Uncomment this to see debug prints
#include "blynk/BlynkSimpleParticle.h"
// Attach a Button widget (mode: Switch) to the Digital pin 7 - and control the built-in blue led.
// Attach a Graph widget to Analog pin 1
// Attach a Gauge widget to Analog pin 2
// No coding is required for direct pin operations!
delay(5000); // Allow board to settle
Blynk.begin(auth);
// Attach a Button widget (mode: Push) to the Virtual pin 1 - and send sweet tweets!
BLYNK_WRITE(V1) {
if (param.asInt() == 1) { // On button down...
// Tweeting!
// Note:
// We allow 1 tweet per minute for now.
// Twitter doesn't allow identical subsequent messages.
Blynk.tweet("My Particle project is tweeting using @blynk_app and it’s awesome!\n @Particle #IoT #blynk");
// Pushing notification to the app!
// Note:
// We allow 1 notification per minute for now.
Blynk.notify("You pressed the button and I know it ;)");
// Attach a Slider widget to the Virtual pin 2 - and control the built-in RGB led!
BLYNK_WRITE(V2) {
if (param.asInt() > 0) {
RGB.control(true);
byte rgb[3];
HsvToRgb(param.asDouble()/255, 1, 1, rgb);
RGB.color(rgb[0], rgb[1], rgb[2]);
RGB.control(false);
if (ModeBtnPressed()) {
Blynk.notify("Mode button was pressed");
// *** Utility functions
bool ModeBtnPressed() {
if(millis() > 5000) {
if(BUTTON_GetDebouncedTime(BUTTON1) >= 50) {
BUTTON_ResetDebouncedState(BUTTON1);
return 1;
return 0;
void HsvToRgb(double h, double s, double v, byte rgb[]) {
double r, g, b;
int i = int(h * 6);
double f = h * 6 - i;
double p = v * (1 - s);
double q = v * (1 - f * s);
double t = v * (1 - (1 - f) * s);
switch(i % 6){
case 0: r = v, g = t, b = p; break;
case 1: r = q, g = v, b = p; break;
case 2: r = p, g = v, b = t; break;
case 3: r = p, g = q, b = v; break;
case 4: r = t, g = p, b = v; break;
case 5: r = v, g = p, b = q; break;
rgb[0] = r * 255;
rgb[1] = g * 255;
rgb[2] = b * 255;
I saw it (“blynk/blynk.h”) in this tutorial (i know he used core not photon), but it works for me at first.
In addition when i try to include blynk library to my code in particle ide it include like first one (“blynk/blynk.h”)
To figure out problem; I create two code, two project and two token. One of this used photon as hardware and the other one is core (which works for me at first).
None of them works.
To summarize, I try all different combinations but i can’t figure out why it doesn’t work.
In docs says “SparkCore.ino example” I think it means “01_Particle.ino” because I couldn’t find “SparkCore”.
I follow all those steps and I just add my token to code (I didn’t change anything, just add token). I used the project which i take from QR code in docs. Although, it doesn’t work.
By the way, thanks for patience and help, even though we couldn’t find any solution.
Hi, I might need to post on different thread, but it is happen to me this couple days where my Android phone: Galaxy S4, could not be used to control Blynk (various code running on ESP8266 and Particle photon). The Apps seems to be running when I press play, and any data sent from hardware was displayed on the phone, but I could not activate buttons, sliders, etc. Also I could not edit on any widgets when on stop mode. I have another phone: galaxy note 3 and Nexus tablet, all working fine. So it could be something happen recently on some type of phone? I did uninstall the Apps on my Galaxy S4 and re-install it again, but the result was the same.
Just to update, what I did is to move the phone to different WiFi network, and it works (monitor as well as control). Then once it work, there was not problem when coming back to the same wifi network. So what ever the problem was, it is something to do with the WiFi router, not with the Apps.
