I’m working in a project with the Electron and a GPS.
i’m using the Library TinyGPS++. It works well but i found that the library has a fault in the radians and degree calculation.
The fault is easy only two brackets are missing:
// Converts degrees to radians.
#define myradians(angleDegrees) (angleDegrees * M_PI / 180.0)
// Converts radians to degrees.
#define mydegrees(angleRadians) (angleRadians * 180.0 / M_PI)
should be this:
#define myradians(angleDegrees) ((angleDegrees) * M_PI / 180.0)
#define mydegrees(angleRadians) ((angleRadians) * 180.0 / M_PI)
I can’t edit this library
What can i do?
UUUUUUPS WRONG BLOG! Sorry
Should go to Particle …
