Particle Photon and DS18b20 temperature sensor
I have used code found in multiple threads but cannot seem to read/write any data from the sensor. I know many people used serial commands but I thought since only one sensor was being used that i could skip that part of the code. At some point i will have 3 of these connected to my project and will be able to use one pin per sensor but if the code is similar all three could occupy one pin i guess. Am i using the correct libraries for this task? Any help would be appreciated!
#include "blynk/blynk.h"
#include "blynk/BlynkSimpleParticle.h"
#include "SparkCorePolledTimer/SparkCorePolledTimer.h"
#include "spark-dallas-temperature/spark-dallas-temperature.h"
#include "OneWire/OneWire.h"
#define ONE_WIRE_BUS 0
OneWire oneWire(ONE_WIRE_BUS); // Setup a oneWire instance to communicate with any OneWire devices (not just Maxim/Dallas temperature ICs)
DallasTemperature sensors(&oneWire); // Pass our oneWire reference to Dallas Temperature.
SparkCorePolledTimer updateTimer(5000); //Create a timer object and set it's timeout in milliseconds
void OnTimer(void); //Prototype for timer callback method
float main, mainRaw, aux, auxRaw, acc, accRaw;
float temp = sensors.getTempCByIndex(0);
char auth[] = "qwerty";
void setup(){
updateTimer.SetCallback(OnTimer);
delay(5000); // Allow board to settle
pinMode(A0, INPUT);
pinMode(A1, INPUT);
pinMode(A2, INPUT);
pinMode(D0, INPUT);
//sensors.requestTemperatures(); // Send the command to get temperatures
sensors.begin(); // IC Default 9 bit. If you have troubles consider upping it 12. Ups the delay giving the IC more time
Blynk.begin(auth);
void loop(){
updateTimer.Update();
void OnTimer(void) { //Handler for the timer, will be called automatically
// read analog ports
mainRaw = analogRead(A0);
auxRaw = analogRead(A1);
accRaw = analogRead(A2);
temp = digitalRead(D0);
main = map(mainRaw, 0, 4096, 0, 1865);
aux = map(auxRaw, 0, 4096, 0, 1865);
acc = map(accRaw, 0, 4096, 0, 1865);
main = (main / 100);
aux = (aux / 100);
acc = (acc / 100);
Blynk.virtualWrite(5, main);
Blynk.virtualWrite(6, aux);
Blynk.virtualWrite(7, acc);
Blynk.virtualWrite(8, temp);
Your code seems to be correct.
Are you able to get the data from the sensor without Blynk?
Try to make sure that everything works first, then add Blynk cherry :cherries: on top of your :cake: :wink:
Nothing was working so i started from scratch. This is code i used to read the address of each sensor. Flash it to the particle then open up a terminal, i used cool-term, and note each address as you connect them individually to D2 (could be any digital pin but the code is written for D2)
OneWire ds = OneWire(D2);  // on pin 10 (a 4.7K resistor is necessary)
unsigned long lastUpdate = 0;
 unsigned long now = millis();
    if((now - lastUpdate) > 3000)
        lastUpdate = now;
        byte i;
        byte present = 0;
        byte addr[8];
      if ( !ds.search(addr)) {
        Serial.println("No more addresses.");
        Serial.println();
        ds.reset_search();
        //delay(250);
        return;
      // the first ROM byte indicates which chip
      switch (addr[0]) {
        case 0x10:
          Serial.println("Chip = DS18S20");  // or old DS1820
          break;
        case 0x28:
          Serial.println("Chip = DS18B20");
          break;
        case 0x22:
          Serial.println("Chip = DS1822");
          break;
        default:
          Serial.println("Device is not a DS18x20 family device.");
          return;
      Serial.print("ROM = ");
      Serial.print("0x");
        Serial.print(addr[0],HEX);
      for( i = 1; i < 8; i++) {
        Serial.print(", 0x");
        Serial.print(addr[i],HEX);
      if (OneWire::crc8(addr, 7) != addr[7]) {
          Serial.println("CRC is not valid!");
          return;
    Serial.println();
      ds.reset();
Now that i have the individual address I need the code to read serial data from each sensor. Currently this code is written for a single sensor connected to D0, and the temp is read from the same terminal program over usb.
#pragma SPARK_NO_PREPROCESSOR
// DS18B20 Thermometer Stuff
#define ONE_WIRE_BUS D0
#define TEMPERATURE_PRECISION 9
//Run I2C Scanner to get address of DS18B20(s)
DeviceAddress inWaterThermometer = { 0x28, 0xFF, 0x33, 0x46, 0x54, 0x15, 0x3, 0x7F };
//CHNAGE TO YOUR DEVICE'S ADDRESS
double InTempC = -1;
double waterTempF = -1;
void update18B20Temp(DeviceAddress deviceAddress, double &tempC);
    // DS18B20 initialization
    sensors.begin();
    sensors.setResolution(inWaterThermometer, TEMPERATURE_PRECISION);
    Serial.begin(9600);   // open serial over USB
        // DS18B20
        update18B20Temp(inWaterThermometer, InTempC);
        waterTempF = (InTempC * 9)/5 + 32;
        Serial.print("Water Temp:");
        Serial.print(waterTempF);
        Serial.println("F");
  tempC = sensors.getTempC(deviceAddress);
I managed to get one sensor working with the rest of my original code but flips the value display in blynk flips between a Celsius reading and -127. Closer than I have ever been though, at least i’m reading temperatures!!
The problem with the first attempt was Blynk.virtualWrite(8, temp(0)); now it is Blynk.virtualWrite(8, sensors.getTempCByIndex(0));
i need to change from reading by index to reading by address, then ill be able to add additional temperature sensors.
Current working code is
#define ONE_WIRE_BUS D0 // Data wire is plugged into pin D0 on the particle
float temp = sensors.getTempCByIndex(0); //0 is first sensor in string?
char auth[] = "token";
void setup(){
pinMode(A0, INPUT);
pinMode(A1, INPUT);
pinMode(A2, INPUT);
pinMode(D0, INPUT);
Blynk.begin(auth);
void loop(){
aux = (aux / 100);
acc = (acc / 100);
Focusing on getting multiple temp sensors on the same pin now, but i keep getting fliers in the readings. mostly -127 which I have read is attributed to a non read of the device. Can I get rid of any lines of code here?
#include "SparkCorePolledTimer/SparkCorePolledTimer.h"  // USED TO SEND PUSH DATA AT INTERVAL SET
char auth[] = "token";   // CHANGE TO BLYNK DASHBOARD TOKEN
#define ONE_WIRE_BUS D0                 // DS18B20 Thermometer Stuff
#define TEMPERATURE_PRECISION 11         // DS18B20 Thermometer Stuff
OneWire oneWire(ONE_WIRE_BUS);          // DS18B20 Thermometer Stuff
DallasTemperature sensors(&oneWire);    // DS18B20 Thermometer Stuff
//CHANGE TO YOUR DEVICE'S ADDRESS
DeviceAddress Thermometer1 = { 0x28, 0xFF, 0x44, 0x50, 0x16, 0x15, 0x3, 0xC };
DeviceAddress Thermometer2 = { 0x28, 0xFF, 0xD5, 0x4D, 0x16, 0x15, 0x3, 0xD3 };
DeviceAddress Thermometer3 = { 0x28, 0xFF, 0x2D, 0x37, 0x16, 0x15, 0x3, 0xF8 };
DeviceAddress Thermometer4 = { 0x28, 0xFF, 0x6A, 0x24, 0x16, 0x15, 0x3, 0xF0 };
double Temp1 = -1;
double Temp2 = -1; // XXXXXXXX
double Temp3 = -1;
double Temp4 = -1;
    sensors.begin();
    sensors.setResolution(Thermometer1, TEMPERATURE_PRECISION);
    sensors.setResolution(Thermometer2, TEMPERATURE_PRECISION);  //  XXXXXXXXXX
    sensors.setResolution(Thermometer3, TEMPERATURE_PRECISION);
    sensors.setResolution(Thermometer4, TEMPERATURE_PRECISION);
    //Blynk initialization
    Blynk.begin(auth);
        // DS18B20
        update18B20Temp(Thermometer1, InTempC);
        Temp1 = (InTempC * 9)/5 + 32;
        update18B20Temp(Thermometer2, InTempC);
        Temp2 = (InTempC * 9)/5 + 32;
        update18B20Temp(Thermometer3, InTempC);
        Temp3 = (InTempC * 9)/5 + 32;
        update18B20Temp(Thermometer4, InTempC);
        Temp4 = (InTempC * 9)/5 + 32;
       // Serial.print("Water Temp:");
        //Serial.print(waterTempF);
       //Serial.println("F");
       delay(5000); // READ DELAY - TOOK THIS OUT AND IT GOT JUMPY WITH -127'S C AND 196'S F
  Blynk.virtualWrite(8, tempC);
  Blynk.virtualWrite(9, Temp1);
  Blynk.virtualWrite(10, Temp2);
  Blynk.virtualWrite(11, Temp3);
  Blynk.virtualWrite(12, Temp4);
I recently started to get strange spikes on DHT22 sensor. Nothing helped until I filtered the values and then averaged them by 100 samples
did you apply that filter to a history widget or when you read the file after it was recorded?
I was lazy to calculate median :slight_smile: so I filter data to ignore outliers, then average 100 readings, then write to Virtual Pin on a History Graph.
do you happen to have an example handy:sunglasses:
Can i get rid of the TempC here
double Temp1 = -1;
double Temp2 = -1;
double Temp3 = -1;
double Temp4 = -1;
or here
//updateTimer.Update();    // new stuff
        // DS18B20
For reference this is what i’m seeing @Pavlo …and thanks for the iOS app update, I got my virtual pins back without rebuilding the dashboard, very nice!
how could I implement something like if reading is less than -30 than don’t send update?
Actually if I only write positive numbers that would be fine too, I tried changing double to float and I get even more -196 fliers. Odd thing now is that they all go to -196 at the same time, before it was one at a time.
I’m using a modified version of: AnalogSmooth Library to smooth analog signal jitter by averaging concurrent readings by Michael Thessel.
I just changed it slightly so that it works not only with Analog Pins, but with any values.
Filtering is a simple if statement:
if ( t < 50 && t > -30){ //checking if value is in the adequate range
      float tempSmooth = as100.smooth(t); //smoothing it with the AnalogSmooth library
      Blynk.virtualWrite(27, tempSmooth); //writing it to the V pin
Thank you, I used if statements as the filter
//SparkCorePolledTimer updateTimer(5000); //Create a timer object and set it's timeout in milliseconds  //new stuff
//void OnTimer(void); //Prototype for timer callback method  // new stuff
double Temp1 = -1;
double Temp2 = -1;
double Temp3 = -1;
double Temp4 = -1;
//Serial.begin(9600);                    //new stuff
//updateTimer.SetCallback(OnTimer);      //new stuff
//delay(5000); // Allow board to settle  //new stuff
    sensors.begin();
Blynk.begin(auth);
        // DS18B20
        //Serial.print("Water Temp:");
if ( tempC < 60 && tempC > -30) {
if ( Temp1 < 150 && Temp1 > -30) {
if ( Temp2 < 150 && Temp2 > -30) {
if ( Temp3 < 150 && Temp3 > -30) {
if ( Temp4 < 150 && Temp4 > -30) {
I take multiple measurements and average them out. There is a an example in my Home Domotics topic. Basically, I take X measurements for a sensor, subtract the highest and lowest value (for reading mistakes) and average out the rest of them.
Thank you @Pavlo and @Lichtsignaal, without your insight it would have taken forever to get this up and running! I now have sensors for voltage temperature and light, with controls for doors locks and engine run, this is very cool.
Now that i have a working system i will tweak the temperature reading to do averaging, probably do the same for the battery voltage. The plan is to have a particle electron with 3g running this so the bandwidth will be a concern at some point. Currently i just run a spare phone has a hotspot and it only pulls a couple hundred MB a day, and thats with flashing code all the time. Here is my code as usual, if theres anything fundamentally wrong please let me know. Im worried that i have some of the timer functions misplaced in the loop.
I love that i can reset the history graphs now, so helpful. Edit: this no longer happens, must have been fixed because I didn’t change anything on my end, well done. - (One thing i have noticed is that if don’t have a value display monitoring a shared channel with the history graph, it will not populate the legend when re-opening the app.)
#define TEMPERATURE_PRECISION 12         // DS18B20 Thermometer Stuff
float main, mainRaw, aux, auxRaw, acc, accRaw, light, lightRaw;
//temp stuff
double Temp1 = -1;
double Temp2 = -1;
double Temp3 = -1;
double Temp4 = -1;
//end temp stuff
void setup(){
    sensors.begin();
pinMode(A0, INPUT);
pinMode(A1, INPUT);
pinMode(A2, INPUT);
pinMode(A5, INPUT);
Blynk.begin(auth);
        // DS18B20
        Temp2 = (InTempC * 9)/5 + 31.33;
        Temp3 = (InTempC * 9)/5 + 31.67;
//left out due to updatetimer in      delay(5000); // READ DELAY - TOOK THIS OUT AND IT GOT JUMPY WITH -127'S C AND 196'S F
    Blynk.virtualWrite(0, tempC);
    Blynk.virtualWrite(21, Temp1);
    Blynk.virtualWrite(22, Temp2);
    Blynk.virtualWrite(23, Temp3);
    Blynk.virtualWrite(24, Temp4);
lightRaw = analogRead(A5);
acc = map(accRaw, 0, 4096, 1000, 1865);
light = map(lightRaw, 0, 4096, 1000, 1500);
aux = (aux / 100);
acc = (acc / 100);
light = (light / 100);
Blynk.virtualWrite(10, main);
Blynk.virtualWrite(11, aux);
Blynk.virtualWrite(12, acc);
Blynk.virtualWrite(25, light);
Once again i need assistance with my code. Trying to get control of my particle on IFTTT and thought that I could define BLYNK_WRITE as a function, i don’t think i’m going about it correctly though. Should i just wait for BLYNK IFTTT integration or should this work work with a little tweaking? Thanks for any help you can offer!
//#pragma SPARK_NO_PREPROCESSOR
#include "MCP23008-I2C/MCP23008-I2C.h"  //I2C STUFF
#define ONE_WIRE_BUS D6                 // Data wire is plugged into pin D5 on the particle
#define lock BLYNK_WRITE(7)             // lock doors
#define unlock BLYNK_WRITE(6)           // unlock doors
char auth[] = "token";  //BLYNK CE3
//char auth[] = "token";  //BLYNK CE2
Adafruit_MCP23008 mcp;                  // I2C STUFF
//defince temp address
//DeviceAddress Thermometer5 = { 0x28, 0xFF, 0xF5, 0x4F, 0x16, 0x15, 0x3, 0x2C };
// define temp bit resolution ie: int, float, double
double Temp1 = -1;
double Temp2 = -1;
double Temp3 = -1;
double Temp4 = -1;
//double Temp5 = -1;
//end temp stuff
 //setupsetupsetupsetupsetupsetupsetupsetupsetupsetupsetupsetupsetupsetupsetupsetupsetupsetupsetupsetupsetupsetupsetupsetupsetup
void setup(){
Blynk.begin(auth);      // BLYNK initialization
Particle.function("lock", lock);
Particle.function("unlock", unlock);
    sensors.begin();    // DS18B20 initialization
//    sensors.setResolution(Thermometer5, TEMPERATURE_PRECISION);
pinMode(A0, INPUT); //
pinMode(A1, INPUT);
pinMode(A2, INPUT);
pinMode(A5, INPUT);
// I2C STUFF
mcp.begin();      // use default address 0
  mcp.pinMode(0, OUTPUT);
  mcp.pinMode(1, OUTPUT);
  mcp.pinMode(2, OUTPUT);
  mcp.pinMode(3, OUTPUT);
  mcp.pinMode(4, OUTPUT);
  mcp.pinMode(5, OUTPUT);
  mcp.pinMode(6, OUTPUT);
  mcp.pinMode(7, OUTPUT);
// END I2C STUFF
}// END VOID SETUP BUT WHAT ABOUT I2C CODE BELOW BEFORE LOOP
// BLYNY WRITE NEEDS TO BE ABOVE LOOP BUT NOT IN SETUP LIKE THIS
// I2C STUFF
BLYNK_WRITE(0) {
    if (param.asInt()) {
        mcp.digitalWrite(0, HIGH);
        delay(3000);
       mcp.digitalWrite(0, LOW);}}
BLYNK_WRITE(1) {
        mcp.digitalWrite(1, HIGH);
       mcp.digitalWrite(1, LOW);}}
BLYNK_WRITE(2) {
        mcp.digitalWrite(2, HIGH);
       mcp.digitalWrite(2, LOW);}}
BLYNK_WRITE(3) {
        mcp.digitalWrite(3, HIGH);
       mcp.digitalWrite(3, LOW);}}
BLYNK_WRITE(4) {
        mcp.digitalWrite(4, HIGH);
       mcp.digitalWrite(4, LOW);}}
BLYNK_WRITE(5) {
        mcp.digitalWrite(5, HIGH);
       mcp.digitalWrite(5, LOW);}}
BLYNK_WRITE(6) {
        mcp.digitalWrite(6, HIGH);
        delay(500);
        mcp.digitalWrite(6, LOW);
        delay(500);
        delay(500);
       mcp.digitalWrite(6, LOW);}}
BLYNK_WRITE(7) {
        mcp.digitalWrite(7, HIGH);
        delay(500);
        mcp.digitalWrite(7, LOW);
        delay(500);
        delay(500);
       mcp.digitalWrite(7, LOW);}}
//I2C STUFF
//looplooplooplooplooplooplooplooplooplooplooplooplooplooplooplooplooplooplooplooplooplooplooploop//looplooplooplooplooplooploopl
        // DS18B20
//        update18B20Temp(Thermometer5, InTempC);
//        Temp5 = (InTempC * 9)/5 + 32.12;
//delay(5000); // READ DELAY - TOOK THIS OUT AND IT GOT JUMPY WITH -127'S C AND 196'S F
// read temperature and discard reading between 150 and -30
//if ( Temp5 < 150 && Temp5 > -30) {
//    Blynk.virtualWrite(25, Temp5);
// map analog input scale output
light = map(lightRaw, 0, 4050, 1100, 1500);
// correct display decimal place
aux = (aux / 100);
acc = (acc / 100);
Blynk.virtualWrite(15, light);
error message
In file included from blynk/BlynkParticle.h:16:0,
                 from blynk/BlynkSimpleParticle.h:14,
                 from blynk/blynk.h:2,
                 from cruisecontrolce2.cpp:2:
blynk/BlynkApiParticle.h:78:6: warning: #warning "analogInputToDigitalPin not defined => Named analog pins will not work" [-Wcpp]
In file included from blynk/BlynkApi.h:17:0,
                 from blynk/BlynkApiParticle.h:15,
                 from blynk/BlynkParticle.h:16,
cruisecontrolce2.cpp: In function 'void setup()':
This looks like an error in blynk library. Would you like to create an issue on GitHub to let the author know?
CREATE ISSUE
CREATE ISSUE
blynk/BlynkHandlers.h:54:5: error: expected primary-expression before 'void'
     void BlynkWidgetWrite ## pin (BlynkReq& request, const BlynkParam& param)
blynk/BlynkHandlers.h:62:31: note: in expansion of macro 'BLYNK_WRITE_2'
 #define BLYNK_WRITE(pin)      BLYNK_WRITE_2(pin)
cruisecontrolce2.cpp:10:14: note: in expansion of macro 'BLYNK_WRITE'
cruisecontrolce2.cpp:46:27: note: in expansion of macro 'lock'
cruisecontrolce2.cpp:11:16: note: in expansion of macro 'BLYNK_WRITE'
cruisecontrolce2.cpp:47:29: note: in expansion of macro 'unlock'
make[1]: *** [../build/target/user/platform-6cruisecontrolce2.o] Error 1
make: *** [user] Error 2
Good afternoon, I would like the libraries used in your project because I am not finding
