Dear Blynker’s,
Help will be apricated!
Sorry about my English ![]()
I’m working on car project based on Particle Electron and Have some problems with blynk cloud server communication .
My goal is to stop the motors fast as possible when no connection to Blynk Server or Internet when the car is moving like that:
12:10:10 car moving - blynk.connected == true
12:10:13 car moving - blynk.connected == true
12:10:16 car moving - blynk.connected == false > stoping motors, reconnect\reset
trying to achieve this goal with BLYNK_HEARTBEAT by checking if blynk.connected == true every 3-4 seconds
then stop motors immediately if blynk.connected == false.
Using BLYNK_HEARTBEAT, maybe not the right way and you have other recommendations…
When BLYNK_HEARTBEAT 30 or more used,
its not good because if the car in moving sate, No possible to stop it at least 30 sec (until blynk.connected == true) if it will be disconnection from server and car will keep moving until next reconnect\reset , So modified the heartbeat to BLYNK_HEARTBEAT 4.
At my sketch below with BLYNK_HEARTBEAT 4 , Every 5-20 minutes
received Heartbeat timeout and its interrupting the communication even when Blynk app open/closed.
With BLYNK_HEARTBEAT 30 ,Every 1-12 hours received Heartbeat timeout even when Blynk app open/closed.
If removing #define BLYNK_HEARTBEAT 4 and #define BLYNK_TIMEOUT_MS 2000UL ,
No Heartbeat timeout for several days and connection stable.
Any suggestions how can I mange the Blynk connection and stop motors at right way and decreasing Heartbeat timeout interrupt will be awesome!
Hardware used: Particle Electron
Electron Firmware: 1.4.4 - latest firmware
Blynk library: 0.6.3, Using Blynk cloud server
Compiled at Particle cloud IDE.
3rd party sim card - 50Gb data plan.
Sketch:
SYSTEM_THREAD(ENABLED);
// Uncomment this, if you want to set network credentials
//#include "cellular_hal.h"
// STARTUP(cellular_credentials_set("apn", "", "", NULL));
// Run "ping blynk-cloud.com", and set Blynk IP to the shown address
#define BLYNK_IP IPAddress(188,166,206,43)
//#define BLYNK_IP IPAddress(45,55,130,102)
// Set Particle keep-alive ping interval, Each ping uses 121 bytes of data.
#define PARTICLE_KEEPALIVE 120
#include <blynk.h>
char auth[] = "yyyxxx";
bool isAppConnected = false;
#define LmotorF D1 // Left motor Forward
#define LmotorB D2 // Left motor Backward
#define RmotorF D3 // Right motor Forward
#define RmotorB D4 // Right motor Backward
BLYNK_APP_CONNECTED() {
isAppConnected = true;
Serial.println("#BLYNK# App Connected");
BLYNK_APP_DISCONNECTED() {
Serial.println("App Disconnected.");
stopMotors();
BLYNK_WRITE(V1) { // Left motor Forward - Button
digitalWrite(LmotorF, param.asInt());
BLYNK_WRITE(V2) { // Left motor Backward - Button
digitalWrite(LmotorB, param.asInt());
BLYNK_WRITE(V3) { // Right motor Forward - Button
digitalWrite(RmotorF, param.asInt());
BLYNK_WRITE(V4) { // Right motor Backward - Button
digitalWrite(RmotorB, param.asInt());
pinMode(LmotorF, OUTPUT);
pinMode(LmotorB, OUTPUT);
pinMode(RmotorF, OUTPUT);
pinMode(RmotorB, OUTPUT);
stopMotors();
Particle.keepAlive(PARTICLE_KEEPALIVE);
Blynk.begin(auth, BLYNK_IP);
timer.setInterval(3000L, checkBlynk);
if(Blynk.connected()){
stopMotors(); // stopping motors if Blynk disconnected
return;
if (isAppConnected == false) {
stopMotors(); // stopping motors if BLYNK_APP_DISCONNECTED
byte counter = 0; // counter for system reset
void checkBlynk() {
Serial.print("Uptime: ");
Serial.print(millis() / 1000);
if (!Blynk.connected()) {
Serial.println("Blynk Disconnected!, reconnecting");
Blynk.connect(10);
Serial.println("Blynk reconnection failed!");
if (counter++ >= 2) { // do reset if not connected to Blynk
System.reset();
Serial.println("Blynk reconnection success!");
Particle.process();
Serial.print("Blynk Connected");
void stopMotors() {
digitalWriteFast(LmotorF, LOW);
digitalWriteFast(LmotorB, LOW);
digitalWriteFast(RmotorF, LOW);
digitalWriteFast(RmotorB, LOW);
```This text will be hidden
