Hello
Im tring to get the Particle boron connected to the new Blynk 2.0 but no luck. The Particle Photon works perfect and connects to the cloud flawlessly . I have went through the steps of setting up the template and device Choosing Particle Boron GSM connection. I used the electron example for the sketch to connect with cellular connection.
#define BLYNK_TEMPLATE_ID "xxxxxxxxx"
#define BLYNK_DEVICE_NAME "Boron Cattle Feeder"
#define BLYNK_AUTH_TOKEN "xxxxxxxxxxxxxxxxxxx"
// Uncomment this, if you want to set network credentials
//#include "cellular_hal.h"
//STARTUP(cellular_credentials_set("broadband", "", "", NULL));
// Run "ping blynk.cloud", and set Blynk IP to the shown address
#define BLYNK_IP IPAddress(45,55,96,146)
// Set Blynk hertbeat interval.
// Each heartbeat uses ~90 bytes of data.
#define BLYNK_HEARTBEAT 60
// Set Particle keep-alive ping interval.
// Each ping uses 121 bytes of data.
#define PARTICLE_KEEPALIVE 20
#include <blynk.h>
void setup() /****** SETUP: RUNS ONCE ******/
{ // Debug console
delay(2000);
Particle.keepAlive(PARTICLE_KEEPALIVE);
Blynk.begin(auth, BLYNK_IP );
I have tried the IP in the example and blynk-cloud.com,80. The IP in the sketch came from pinging blynk-cloud.com. If there is something else I need to do or do something completely different please let me know but at this point im at a stand still. Been at this for a couple hours with no luck. Any help is appreciated!!
