I have a simple application and the Particle Argon keeps disconnecting from Blynk (according to the application) . The Application is on an Android Note 8. It works on and off, but I should get a “ping” about every 10 minutes, They get to blynk once in a while because it shows the Argon as disconnected but I receive the write signal indicating the Argon is online and working.
The simple program is:
#include <blynk.h>
char auth[] = "Whatever" ;
Particle.publish("Setup Start", "Blynk", PRIVATE); // publish to cloud
Blynk.begin(auth);
Particle.publish("Setup End", "Blynk", PRIVATE); // publish to cloud
Blynk.virtualWrite(V1, String(76.6)); // Farenheit Temprature
Particle.publish("Blynk", "Wrote", PRIVATE); // publish to cloud
delay(30000 * 10);
