Panic core_esp8266_main.cpp:206 loop_task
Panic core_esp8266_main.cpp:206 loop_task.
How to fix this error?
Thank you!!!
[Unformatted serial output removed by moderator]
@jasonwu Please edit your post, using the pencil icon at the bottom, and add triple backticks at the beginning and end of your serial monitor text so that it displays correctly.
If you want assistance with this issue then at the very least you also need to post your sketch - correctly formatted with triple backticks too of course.
