I created a simple app based on the example, and use the serial link to connect. After a reset of the arduino i can turn the onboard LED on and off using a button but it doesn’t glow full brightness. if i stop the app using the square and then hit the play again then it works full brightness again
* Downloads, docs, tutorials: http://www.blynk.cc
* Blynk community: http://community.blynk.cc
* Social groups: http://www.fb.com/blynkapp
* http://twitter.com/blynk_app
* This example shows how to use ordinary Arduino Serial
* to connect your project to Blynk.
* Feel free to apply it to any other example. It's simple!
* 1. Optional, but recommended.
* Connect additional USB-serial adapter to see the prints.
* 2. Edit auth token and upload this sketch.
* Be sure to select the right port (there may be multiple).
* 3. Run the script (it will redirect traffic to server):
* for Windows: scripts/blynk-ser.bat
* for Linux and OSX: ./scripts/blynk-ser.sh (may need to run with sudo)
* You can specify port, baud rate, and server endpoint like this:
* ./blynk-ser.sh -c <serial port> -b <baud rate> -s <server address> -p <server port>
* Run blynk-ser.sh -h for more information
* Attention!
* Arduino IDE may complain with "programmer is not responding".
* You need to terminate script before uploading new sketch.
* 4. Start blynking! :)
SoftwareSerial SwSerial(10, 11);
#define BLYNK_PRINT SwSerial
#include <BlynkSimpleSerial.h>
char auth[] = "mytokenhere";
SwSerial.begin(9600);
Blynk.begin(auth, 9600);
// Setup function to be called each 1000 milliseconds
timer.setInterval(1000, sendUptime);
void sendUptime()
// Please don't send more that 10 values per second!
Blynk.virtualWrite(5, millis()/1000);
