I’d like to understand the order of execution of the blynk functions at startup .
for example this simplified sketch:
Blynk.begin(auth, server_ip, 8080, arduino_ip, dns_ip, gateway_ip, subnet_mask, arduino_mac);
//other setup: GPIO, Functions...
BLYNK_CONNECTED() { //update the values }
void loop(){
What is the correct order?
1-blynk begin function,
2-BLYNK_CONNECTED() function
3- //other setup: GPIO, Functions…
or
2-//other setup: GPIO, Functions…
3-BLYNK_CONNECTED() function
its a good question, and it can be answered by placing Serial.println(); commands
in setup() and BLYNK_CONNECTED(); and see what order they occur.
My guess is the latter… i.e. during Blynk.run()
Setup runs first and only once.
loop runs all the time but not untill after setup has completed.
blynk_connected only runs once when loop is running and the app gets connected.
I just tried this bit of code:
Serial.begin(57600);
Serial.println("about to do Blynk.begin");
// <------------------------------------------------BLYNK_CONNECTED executes here
Serial.println("Blynk.begin completed");
delay(100);
Serial.println("Void setup 1");
delay(100);
Serial.println("Void setup 2");
BLYNK_CONNECTED()
Serial.println("Blynk Connected executed");
Serial.println("Void Loop, about to do Blynk.run");
Serial.println("Void Loop, Blynk.run completed");
which produces this output in the serial monitor:
[5398] Connecting to UltraNet
[15901] Connected to WiFi
[15901] IP: 192.168.1.27
[15901]
___ __ __
/ _ )/ /_ _____ / /__
/ _ / / // / _ \/ '_/
/____/_/\_, /_//_/_/\_\
/___/ v0.6.1 on ESP8266
[15914] Connecting to blynk-cloud.com:80
[16084] Ready (ping: 56ms).
Void setup 1
Void setup 2
This shows that BLYNK_CONNECTED
is executed IMMEDIATELY after the device has connected to Blynk, before the any further lines of code in void setup.
So this means that:
is the correct answer.
