I am running ESP32 Devkit v1, Arduino IDE and Blynk 2.0 with Edgent.
I have an Openweather API Call that has worked well for last 18 months on both Blynk1.0 and up until today on Blynk2.0 (Serial connection)
When I then added Edgent, (Which works brilliantly), although I didn’t change any of the working code, the serial monitor showed me that the call too the Openweather API was not happening. Clearly something to do with wifi credentials etc. I have read a number of similar posts and support that has been given on similar topics but got a bit lost in the Documentation, discussion on web hooks etc and I suspect it is something fairly simple (Adding in some other libraries, or accessing wifi credentials or checking for connection?)
I have extracted the relevant code below (but excluded the any other functions, declarations etc all of which is working fine. The open weather call stopped producing results as soon as I went to Edgent. Happy to post the full code if required (But it is very long - clearly need to separate this out into other files but still debugging and working through the logic including trying to then rewrite in to a future state machine!)
#define BLYNK_TEMPLATE_ID "TMPL6DiA3dgE"
#define BLYNK_DEVICE_NAME "Herb Garden"
#define BLYNK_FIRMWARE_VERSION "0.1.9"
#define APP_DEBUG
//LIBRARIES
#include "DHT.h"
#include "BlynkEdgent.h"
#include <OpenWeatherOneCall.h>
// Define OneCall API KEY and invoke the library
#define ONECALLKEY "RedacateKeyGoesHere" //my private key for the openweather API calls. Redacted for security!
OpenWeatherOneCall OWOC;
// Define 12v Pump, Solenoid and Virtual Pins
#define WATER_PUMP_PIN 23 //D23
#define WATER_SOLENOID_PIN 13
#define VPIN_BUTTON_1 V1
#define VPIN_BUTTON_2 V2
#define VPIN_BUTTON_C V9
#define VPIN_IS_IT_RAINING V12
#define VPIN_RAIN_LAST_FIVE V40
#define VPIN_RAIN_LAST_HOUR V41
#define VPIN_RAIN_TODAY V42
#define VPIN_DESIRED_MOISTURE V77
// Relay State
bool toggleState_1 = LOW; //Define integer to remember the toggle state for relay 1
bool toggleState_2 = LOW; //Define integer to remember the toggle state for relay 2
// Oneweather forecast and icons function
void setBlynkWeather() {
int status = WL_IDLE_STATUS;
char server[] = "api.openweathermap.org";
String location = "Reading, UK";
// OpenWeatherOneCall variables
float myLATITUDE = 51.51119916275342; //<-----Crowsley, Henley-on Thames
float myLONGITUDE = -0.9597222296547302; //<-----Crowsley, Henley-on-Thames
int myCITYID = 2639577; //For City ID Location setting if used - READING
int myUNITS = METRIC; //<-----METRIC, IMPERIAL, KELVIN (IMPERIAL is default)
int myHISTORY = NULL; //<-----Only required for historical data up to 5 days. NULL means no historical data as cant get current and historical
int myEXCLUDES = EXCL_C + EXCL_D + EXCL_M + EXCL_A; //<-----0 Excludes is default. EXCL_C=Current; EXCL_H= Hour; EXCL_M = Minutes; EXCL_A= ALerts
//for debugging loop counting
int nextCall = 0;
// First set My Open Weather Key value
OWOC.setOpenWeatherKey(ONECALLKEY);
// Second set my position (can be CITY ID, IP ADDRESS, GPS, or Manual LATITUDE/LONGITUDE)
OWOC.setLatLon(myLATITUDE, myLONGITUDE);
OWOC.setDateTimeFormat(DMY24H);
OWOC.setExcl(myEXCLUDES); // Third set any EXCLUDES if required
OWOC.setHistory(myHISTORY); // Set History if you want historical weather but I am defaulting to Null
OWOC.setUnits(myUNITS); // Set UNITS of MEASURE to Metric otherwise default is IMPERIAL
//Now call the weather.
OWOC.parseWeather();//.
printf("\nLocation: % s, % s % s\n", OWOC.location.CITY, OWOC.location.STATE, OWOC.location.COUNTRY); //Now display some information
Blynk.virtualWrite(V33, OWOC.location.CITY); //update the dashboard to show we are pulling the right weather
//Verify all other values exist before using. Remember you can't get historical and current weather at the same time
if (myHISTORY) {
if (OWOC.history) {
printf("Mean Temp for % s : % .0f\n", OWOC.history[0].weekDayName, OWOC.history[0].temperature);
if (OWOC.current) {
printf("Current icon is : %s\n", OWOC.current->icon);
if (OWOC.hour) { //update for todays weather
Blynk.virtualWrite(V24, (OWOC.hour[0].pop));
Blynk.virtualWrite(V21, (OWOC.hour[0].temperature));
Blynk.virtualWrite(V22, (OWOC.hour[0].apparentTemperature));
Blynk.virtualWrite(V23, (OWOC.hour[0].pressure));
// Blynk.virtualWrite(V25, (OWOC.hour[0].dayTime));
Blynk.virtualWrite(V26, (OWOC.hour[0].summary));
Blynk.virtualWrite(V30, (OWOC.hour[0].windSpeed));
Blynk.virtualWrite(V31, (OWOC.hour[0].windBearing));
Blynk.virtualWrite(V32, (OWOC.hour[0].dewPoint));
Blynk.virtualWrite(V34, (OWOC.hour[0].rainVolume));
printf("temp H is: % .2f\n", OWOC.hour[0].temperature);
printf("pressure is: % .0f\n", OWOC.hour[0].pressure);
printf("summary is: % s\n", OWOC.hour[0].summary);
printf("windspeed is: % .0f\n", (OWOC.hour[0].windSpeed));
printf("windbearing is: % .0f\n", (OWOC.hour[0].windBearing));
printf("dewpoint is: % .2f\n", (OWOC.hour[0].dewPoint));
printf("Chance of rain% is: % .2f\n", (OWOC.hour[0].pop));
printf("icon case number is: % .0f\n", OWOC.hour[0].id);
if (OWOC.alert) {
printf("ALERT *** ALERT *** ALERT\n");
printf("Sender : % s\n", OWOC.alert->senderName);
printf("Event : % s\n", OWOC.alert->event);
printf("ALERT : % s\n", OWOC.alert->summary);
//Main Setup Function
void setup(){
pinMode(WATER_PUMP_PIN, OUTPUT);
pinMode(WATER_SOLENOID_PIN, OUTPUT);
pinMode(REED_PIN, INPUT_PULLUP);
pinMode(TRIG_PIN, OUTPUT); // Sets the trigPin as an Output
pinMode(ECHO_PIN, INPUT); // Sets the echoPin as an Input
attachInterrupt(digitalPinToInterrupt(REED_PIN), reedSwitch_ISR, FALLING); // <----- changed to this line
//During Starting all Relays should TURN OFF
dht.begin();
digitalWrite(WATER_PUMP_PIN, HIGH);
digitalWrite(WATER_SOLENOID_PIN, HIGH);
BlynkEdgent.begin();
timer.setInterval(1000L, readDHTSensor);
timer.setInterval(1000L, setMoistureReading);
timer.setInterval(1000L, RainfallTippingBucket);
timer.setInterval(15000L, getButtWaterLevel);
setBlynkWeather();
BlynkEdgent.run();
