So I created a device that clamps on my door lock. To that device is hooked a servo that needs to rotate 90 degrees counterclockwise when I press a virtual button on Blynk and 90 degrees clockwise when I hit that button again. (There is just one servo for the whole project)
Additionally I would like to have a display indicator to know if the door is opened or closed.
Virtual button on Blynk pushed first time (unlocking door):
Virtual display indicates door locked
90 degrees counterclockwise on servo
Wait 1 second
90 degrees clockwise on servo
Virtual display indicates door unlocked
Virtual button on Blynk pushed second time (locking door):
You will need to read up about how to best utilize Blynk in the Documents, Help Center and Sketch Builder… all those links are at the upper right of this page. Everything you need to get started.
Then, during that process. we (other Blynk users like yourself) are here to assist, as best able, with any questions you have.
Thanks for your answer!
You’re absolutely right not looking for someone to write code for me.
I wanted to see if anyone had tips on where to find more information for that kind of use. I couldn’t find much on forums… Most blynk projects either do not use sparkfun products or do not play with sparkfun’s code…
I’m having a hard time finding the library and where to input my code.
If you know of any resource that can guide me I would love the help.
If not, I’ll continue my researches.
There is a whole bunch of examples using that board in the Sketch Builder. And as @Costas pointed out, it just appears to be just a rebranded ESP that uses the same code as Arduino. So lots of code and examples throughout this forum.
