Only one event can be triggered
Hi, something wrong is happening with my events.
I have 2 events called “min_temp” and “max_temp” but only the second one can trigger a notification, the code is the same for both of the function that triggers a notification but “min_temp”, even if on the serial monitor shows it work, on blink doesn’t show nothing.
I tried to swap the 2 events in the code but still the same result.
Here it is my code:
#include <Arduino.h>
#include <ESP8266WiFi.h>  //https://github.com/esp8266/Arduino
//Temperature libraries
#include <OneWire.h>
//Wifi Manager libraries
#include <DNSServer.h>
#include <ESP8266WebServer.h>
#include <WiFiManager.h>
//Blynk connection libraries
//Blynk ID
#define BLYNK_TEMPLATE_ID           ""
#define BLYNK_TEMPLATE_NAME         ""
#define BLYNK_AUTH_TOKEN            ""
#define BLYNK_FIRMWARE_VERSION      "0.1.0"
//#define BLYNK_PRINT Serial
#define INTERVAL 1000l     //BlynkTimer timer interval
void tempRequest();       //temperature reading function
#define TEMP_PIN 12   //temperature sensor signal pin
#define MIN_TEMP 0    //min temperature threshold
#define MAX_TEMP 100  //max temperature threshold
OneWire oneWire(TEMP_PIN);
DallasTemperature temp(&oneWire);
float temp_C;                       //temperature variable in celsius
int trs_min, trs_max, trs_pointer;  //thresholds
bool alert_sent = false;            //alert flag variable
  temp.begin();
  //BEGIN WIFI MANAGER CONFIG
  WiFiManager wifiManager;
  wifiManager.setTimeout(120);
  if (!wifiManager.autoConnect("WiFi Temperature", "password"))
    Serial.println("failed to connect, we should reset as see if it connects");
    delay(3000);
    ESP.reset();
    delay(5000);
//BLINK SETUP AND CONNECTION
  Blynk.begin(BLYNK_AUTH_TOKEN, WiFi.SSID().c_str(), WiFi.psk().c_str());
  Blynk.syncAll();
  timer.setInterval(INTERVAL, tempRequest);
void tempRequest()
  temp.requestTemperatures();
  temp_C = temp.getTempCByIndex(0);
  Serial.print("Temperature is: ");
  Serial.print(temp_C, 1);
  Serial.println(" C");
  Serial.println("  ");
  Blynk.virtualWrite (V0, temp_C);   //send temperature value to blynk
/*Warning notification*/
  if (temp_C > trs_max && alert_sent == false)
    Blynk.logEvent("max_temp"); //send push notification to app
    alert_sent = true;
    Serial.println(alert_sent);
    Serial.println ("TEMPERATURE IS TOO HIGH");
  else if (temp_C <= trs_max && temp_C > trs_min && alert_sent == true)   //if temp. goes below threshold  flag variable is reset
    alert_sent = false;
    if (temp_C < trs_min && alert_sent == false)
    Blynk.logEvent("min_temp"); //send push notification to app
    alert_sent = true;
    Serial.println ("TEMPERATURE IS TOO LOW");
  else if (temp_C >= trs_min && temp_C < trs_max && alert_sent == true)   //if temp. goes below threshold  flag variable is reset
    alert_sent = false;
/*INCREMENT/DECREMEN MAX*/
BLYNK_WRITE (V1)
  int pinData = param.asInt();
  if (trs_pointer == 0)
    if (pinData == 1)
      if (trs_max == MAX_TEMP)
        trs_max = MAX_TEMP;
        trs_max ++;
      Blynk.virtualWrite (V3, trs_max);
    if (pinData == 1)
      if (trs_min == trs_max -2)
          trs_min = trs_max - 2;
          trs_min ++;
        Blynk.virtualWrite (V4, trs_min);
/*DECREMENT*/
BLYNK_WRITE (V2)
      if (pinData == 1){
        if (trs_max == trs_min + 2)
          trs_max = trs_min + 2;
          trs_max --;
      if (pinData == 1)
        if (trs_min == MIN_TEMP)
          trs_min = MIN_TEMP;
          trs_min --;
/*SYNC MAX THRESHOLD*/
BLYNK_WRITE(V3)
  trs_max = param.asInt();
/*SYNC MIN THRESHOLD*/
BLYNK_WRITE(V4)
  trs_min = param.asInt();
/*THRESHOLD POINTER*/
BLYNK_WRITE(V5)
  trs_pointer = param.asInt();
And how are your Events and the associated Notifications configured?
I made them on the console in the section events.
I set up the names ,the priority and I toggle “Show event in Notifications section of mobile app” and “Send event to Timeline”, the trigger is set to 1 event and timer is set to 1 minute.
They are identical the only difference is the name.
I forgot to mention that yesterday they worked and I didn’t change anything in the code.
