Only one data stream in the Maker plan?
Hi Blynk folks,
I’m on the Maker plan — does that mean I only get one data stream now?
Thanks.
The current Free plan gives 20 datastreams per template, and 10 templates.
I assume that you’re referring to the SuperChart widget, which only allows one datastream to be plotted per SuperChart in the Free version.
Yes, I’m referring to the SuperChart widget. I’m on the Maker Plan ($7/month). When I add a second datastream, it appears but doesn’t plot anything.
The Maker plan no longer exists for new subscriptions, but you’ll be able to carry-on using it while you keep-up your subscription payments. Because it’s no longer available, I can’t look-up what was included with that plan, but if you’re only able to add one correctly configured integer or float datastream to your superchart then presumably that is what you’re limited to.
Thank you for looking into this, I figured out what was he problem, it’s working now.
