One token two dashboard?
Hello
can i display data from one token to two dashboards.
I want to display history graph in separate dashboard.
Also tell how fast I can send data to local server. If i am sending 4 values and timer is set for 250 millis node getting disconnected. I am using esp with arduino mini pro and softserial.
Any help or suggestion will be greatly appreciated. :grinning:
not at the moment. We are working on it.
As quick as you can. The problems are always on hardware side.
99% problem is in wiring. Please use search here. There were a lot of disconnection issues and ESP.
Thanks. Will try again using arduino tx rx and hardserial
