One ESP8266 4 smart phones
Newbie here
I will like to create garage door opener.
I use esp8266 and iPhone and works OK
I need to install blynk app on other family members smartphone.
How can I do this?
Blynk server
Latest Blynk Lib I just installed Blynk and new to Blynk.
Thank you for any help.
// ESP8266_Blynk_Simple.ino
// Template Blynk Blink
    Follow us:                  http://www.fb.com/blynkapp
                                http://twitter.com/blynk_app
  You’ll need:
   - Blynk App (download from AppStore or Google Play)
   - Adafruit Huzzah board
  started. Think of them as LEGO bricks  and combine them as you wish.
  example.
char auth[] = "336a9248d8a94dd0a0292d2b55*********";
char ssid[] = "**";
char pass[] = "**";
  // to avoid delay() function!
in app setup - Generate Link you will get a QR
use your family phone scan this QR
they will get access to your app
@csmcvea You can try the sharing method as above, but it will be read only (they can’t change anything), and you MUST have the project actively running on your phone in order for them to see it. Also I am unsure if you can have more then one share at a time??
Look here for a bit more info…
https://www.youtube.com/watch?v=BTo_55Qum2E
However as long as you can "train " others to not mess with the project settings in edit mode, a better way will be to simply have each one log into the same account.
Sharing was made specifically for that
http://docs.blynk.cc/#sharing
Thank you
Very helpful
