Hi This is my first post. I have searched at some length for a solution. My project is used to control two relays which controls two water pumps. Unfortunately if not careful both pumps can be active at the same time.
My problem is to not have both buttons active at once
The solution would be to deactivate the other button when one is active.
V0-Display
V1-Display
V3-Button(clear)
V4-Button(pump)
V5-Menu
V6-RTC
V7-LCD
V10-Table
//#define BLYNK_DEBUG // Comment this out to disable debug and save space
#include <ESP8266WebServer.h>
//#include <SimpleTimer.h>
#include <TimeLib.h>
#include <WidgetRTC.h>
#include <Ticker.h> //for LED status
Ticker ticker;
char auth[] = "";
char ssid[] ="";
char pass[] ="";
WidgetRTC rtc;
//BLYNK_ATTACH_WIDGET(rtc, V6)
WidgetTerminal terminal(V2);
WidgetLCD lcd(V7);
bool simulation = false;
byte sensorInterrupt = 4; // WeMos & NodeMCU D2
byte sensorPin = 4; // WeMos & NodeMCU D2
byte pumpInterrupt = 5; //2; //5; // WeMos D1 ModeMCU D3
byte pumpPin = 5; //2; //5; // WeMos D1 ModeMCU D3
// The hall-effect flow sensor outputs approximately 4.5 pulses per second per litre/minute of flow.
float calibrationFactor = 4.5;
volatile byte pulseCount;
float flowRate;
unsigned int flowMilliLitres;
unsigned long totalMilliLitres;
unsigned long oldTime;
#define averageperiod 5 // currently set to average the flow every 5 seconds
int countseconds = 0; // count up to averageperiod
int averageflow = 0; // used for averaging flow over averageperiod
bool notificationsent = false; // to ensure just one message for each flow start
bool pumpState = false; // pump is OFF on start up
bool masterState = false; //
bool flowoffprintonce = false; // to ensure just one serial and terminal print for each flow stop
int rowIndex = 0; //Saurabh
String currentDate ;
String daybefore;
int rtctimer = 1; //check if RTC is OK and then disable / delete this #1 timer
int currentDatesi = 0; //Saurabh simulation
int daybeforesi=currentDatesi;
int menu=0;
int s;
Serial.println();
pinMode(sensorPin, INPUT);
digitalWrite(sensorPin, HIGH);
pinMode(pumpPin, OUTPUT);
digitalWrite(pumpPin, LOW); // ACTIVE HIGH, pump relay set to OFF on restart
flowMilliLitres = 0;
totalMilliLitres = 0;
oldTime = 0;
flowRate = 0.0;
if(simulation == true){
pulseCount = 47;
else{
pulseCount = 0;
// Configured to trigger on a FALLING state change (transition from HIGH state to LOW state)
attachInterrupt(sensorInterrupt, pulseCounter, FALLING);//FALLING
// Configured to trigger on a CHANGE state change LOW to HIGH or HIGH to LOW
attachInterrupt(pumpInterrupt, pumpToggle, CHANGE);
rtc.begin();
terminal.println("Connected to Blynk");
terminal.println(WiFi.localIP());
terminal.flush();
timer.setInterval(1000L, showFlow);
timer.setInterval(100L, pumpControl); // check if pump needs to be switched ON or OFF every 0.1s
rtctimer = timer.setInterval(2000L, checkRTC); // check every 2s if RTC is correct
BLYNK_CONNECTED() {
Blynk.syncVirtual(V5);
Blynk.syncVirtual(V4);
void showFlow() // average the flow over averageperiod
detachInterrupt(sensorInterrupt); // Disable the interrupt while calculating flow rate and sending the value to the host
// Because this loop may not complete in exactly 1 second intervals we calculate
// the number of milliseconds that have passed since the last execution and use
// that to scale the output. We also apply the calibrationFactor to scale the output
// based on the number of pulses per second per units of measure (litres/minute in
// this case) coming from the sensor.
flowRate = ((1000.0 / (millis() - oldTime)) * pulseCount) / calibrationFactor;
// Note the time this processing pass was executed. Note that because we've
// disabled interrupts the millis() function won't actually be incrementing right
// at this point, but it will still return the value it was set to just before
// interrupts went away.
oldTime = millis();
// Divide the flow rate in litres/minute by 60 to determine how many litres have
// passed through the sensor in this 1 second interval, then multiply by 1000 to
// convert to millilitres.
flowMilliLitres = (flowRate / 60) * 1000;
// Add the ml passed in this second to the cumulative total
totalMilliLitres += flowMilliLitres;
// Print the flow rate for this second in litres / minute
Serial.print("Flow rate: ");
Serial.print(int(flowRate)); // Print the integer part of the variable
Serial.print("L/min");
Serial.print("\t"); // Print tab space
// Print the cumulative total of litres flowed since starting
Serial.print("Output Liquid Quantity: ");
Serial.print(totalMilliLitres);
Serial.print("mL");
Serial.print(totalMilliLitres/1000);
Serial.println("L");
if(simulation != true){
pulseCount = 0; // Reset the pulse counter so we can start incrementing again
countseconds++;
if(countseconds > 0){ // used to skip the first rogue data flow reading
averageflow = averageflow + flowRate; // used to calculate the average flow over averageperiod cycles
if(countseconds == averageperiod){
Serial.print("Average water flow in litres / M is ");
Serial.println(averageflow / averageperiod);
Blynk.virtualWrite(V0, int(averageflow) / averageperiod);
Blynk.virtualWrite(V1, totalMilliLitres/1000);
countseconds = 0; // reset the counter
chkFlow();
averageflow = 0; // reset the average but only after chkFlow() function
attachInterrupt(sensorInterrupt, pulseCounter, FALLING); // Enable the interrupt again now that we've finished sending output
void chkFlow(){
if((averageflow > 3) && (notificationsent == false)){ // guess of a decent water pressure
Serial.println("Water IS flowing.");
lcd.clear();
lcd.print(0,0,"Water is flowing");
Blynk.email("Water Flow Sensor", "Water IS flowing.");
Blynk.notify("Sensor: Water IS flowing.");
notificationsent = true; // stop getting messages until water stops flowing and starts again
flowoffprintonce = false; // when water stops flowing again we can restart serial and terminal print (once)
if((averageflow <= 3)&& (flowoffprintonce == false)){
Serial.println("Water is NOT flowing.");
lcd.clear();
lcd.print(1,0,"Water is NOT");
lcd.print(4,1,"flowing");
notificationsent = false; // when water starts flowing again we can send another notification
flowoffprintonce = true; // stop serial and terminal prints after first pass of water stopping
s=0;
if(averageflow <= 3){
digitalWrite(pumpPin, LOW); // turn off pump //s*
if(averageflow>3 && menu == 1){
digitalWrite(pumpPin, HIGH); // turn on pump //s*
Blynk.virtualWrite(V8, "ON");
Blynk.virtualWrite(V4, 1); // update app button on V4 COSTAS//s*
void pulseCounter()
pulseCount++; // Increment the pulse counter
void pumpToggle(){ // toggle just pumpState OFF and ON from pin interrupt
pumpState = !pumpState; // don't do anything else in this function or the system will crash
//Serial.println(pumpState); // for debugging only TODO comment this out later
void pumpControl() // toggle pump OFF and ON
detachInterrupt(pumpInterrupt); // disable interrupt
if(pumpState == masterState){
// do nothing
else{
masterState = pumpState;
if(pumpState == true){
// Blynk.setProperty(V8, "color","#48E06B");
Serial.println("Pump turned ON");
else{
Blynk.virtualWrite(V4, 0);
Blynk.virtualWrite(V8, "OFF");
// Blynk.setProperty(V8, "color","#04C0F8");
Serial.println("Pump turned OFF");
terminal.flush();
attachInterrupt(pumpInterrupt, pumpToggle, CHANGE); // enable pump pin interrupt
void checkRTC(){
if(year() != 1970){
timer.disable(rtctimer); // disable rtctimer now RTC is ok
//rtcupdated = true; // can be commented out as checkRTC will stop when RTC is ok
currentDate = String(day()) + "/" + month() + "/" + year(); // etc
terminal.println("RTC started");
daybefore=currentDate;
timer.setInterval(60000L, table); //start table() now RTC is OK
void table() //Saurabh
if(currentDate != daybefore)
//currentDate = String(day()) + "/" + month() + "/" + year();
Blynk.virtualWrite(V10, "add", rowIndex,daybefore,totalMilliLitres/1000+String(" litre")); //Saurabh
Blynk.virtualWrite(V1, 0);
Serial.println("working");
BLYNK_WRITE(V3){ // reset with button in PUSH mode on virtual pin 3
int resetdata = param.asInt();
if(resetdata == 1){
Serial.println("Clearing data");
Blynk.virtualWrite(V0, 0);
averageflow = 0;
countseconds = 0;
BLYNK_WRITE(V20){ // reset with button in PUSH mode on virtual pin 20
if(resetdata == 1){
Serial.println("Clearing table data");
Blynk.virtualWrite(V10, "clr");
BLYNK_WRITE(V4){ // Button in SWITCH mode on virtual pin 4 to control relay
int controlRelay = param.asInt();
if(controlRelay == 1){
digitalWrite(pumpPin, HIGH); // turn relay ON
// Blynk.virtualWrite(V8, "ON");
else{
digitalWrite(pumpPin, LOW); // turn relay OFF
//Blynk.virtualWrite(V8, "OFF");
pumpControl();
BLYNK_WRITE(V5)
switch(param.asInt()){
case 1:{
lcd.clear();
lcd.print(1,0,"Automatic Mode");
lcd.print(5,1,"Selected");
menu=1;
break;
case 2:{
lcd.clear();
lcd.print(3,0,"Manual Mode");
menu=0;
break;
void loop(){
