So far I managed to use my server.properties and editing it with a text editor, but I cant find where to put my mail.properties
Just to clarify, I have a server running OpenMediaVault, running Blynk in Docker (which have his persistent folder), and the Docker folder of “/config” is shared over SMB to my notebook.
The /config folder is where I put my server.properties and works fine, but I’ve tried to put mail.properties there and didn’t work.
I have /data folder persisting too, where I can put my .pem files, have my .user files, and logs… Acutally, all data related. Tried to put mail.properties there but didn’t work too:
Hello! It’s very odd since I have mail.properties inside my /config (with server.properties that work, if I edit this and restart Docker I can see the change in Dashboard) and inside my /data
You give me a clue of what to do and I’m gonna document it here so if anyone have same problem can try to do this:
First I oppened my server terminal, then I run
docker exec -it blynk bash
Blynk is my container name, if the container is named banana you should type banana instead
This will let you bash INSIDE docker container.
The default folder when I entered was /data (this is where my mail.properties was), type
cd /
this will move you to “root” of container
Here I had a folder named blynk, when I opened it I can see it have the “server.jar” file
You may need to search where is your “server.jar” navigating trough folders using ls (to list folders) and cd “foldername” to enter it, and using ls again to view files inside that folder.
Back to root (“cd /”) I send the following command:
cp /data/mail.properties /blynk/
Now you can enter the folder where “server.jar” was (mine was “blynk”) and type ls, you need to see your mail.properties with server.jar
This will copy yout mail.properties from /data to /blynk folder, then I restarted docker container and it works!
Hi Hlino,
I’ve OMV3 and various docker runing (unifi, logitech media server…) and all ok, but I’ve a problem with Blynk, don’t start. In the log “service stopped”. Can you help me to configure the docker plugin for run in OMV?
I’m pretty new to docker.
Could anyone explain how to configure Blynk docker inside the GUI of OpenMediaVault?
Any hints to where I can read more about that topic are welcome.
Thanks.
I just came through this thread and was not totally happy with the given solution because this way, the mail.properties file inside the container will be lost each time you upgrade the container.
Instead, you can simply mount the file directly to the /blynk folder by adding:
That’s the best solution! I would add that you should use --mount instead of -v for a new deployment. Since mail.properties doesn’t exist yet, -v would create a folder bind instead of a file bind.
The full command should look something like: $ mkdir -p ~/blynk-server/server/Docker $ touch ~/blynk-server/server/Docker/mail.properties $ docker run --name blynk-server -v ~/blynk-server/server/Docker:/data --mount type=bind,target=/blynk/mail.properties,src=/home/pi/blynk-server/server/Docker/mail.properties -p 8440:8440 -p 8080:8080 -p 9443:9443 -d linuxkonsult/rasbian-blynk
