BLYNK
BLYNK.IO       📲 GETTING STARTED       📗 DOCS       ❓HELP CENTER       👉 SKETCH BUILDER
Old Blynk + new Blynk app
Dear all, may I use both old and new Blynk app on my Android device? Will I have trouble with old version if I install new one? Thank you
Yes you can have the 2 Apps, no trouble :stuck_out_tongue_winking_eye:
3 posts were split to a new topic: Add my esp32 in new blynk
Thank you
Just be aware that if you want to compile code for the old version of Blynk you ought to be using version 0.6.1 of the library, and the new version requires the latest version (currently 1.0.0).
Thanks Pete, so I can’t use new version 1.0.0 for coding my “old” devices (that are running on Blynk Old). Is it correct? I’ve already updated to 1.0.0
That’s correct. It’s a simple task to download the earlier version of the library if you need to recompile code for the old version.
