With Siri I call a virtual pin that triggers it high and I use a Lambda timer to trigger the low after a designated number of millis().
Your description would be much simpler to follow if you differentiated between physical buttons and button widgets.
If you’re using button widgets then I’d recommend attaching them to virtual pins instead of digital pins. This will also make IFTTT integration with Google Assistant much easier.
Hi PeteKnight,
is there a guide for this, I am googling but landing in all sorts
A guide for what part of your project exactly?
The very basics 101, i.e assigning these buttons to a virtual pin, because truly I don’t understand the purpose of virtual pins.
Is a way in plain English that describes how a virtual pin plays a role in what I am trying to do?
I guess I’ll try to work out the integration later.
Also, I used to edit /update my sketch by plugging in via USB. I’m using a nodemcu on my home WiFi. It’s it possible to update the sketch wirelessly?
Okay, I’ve written this just for you (not really :grinning…
Yes, you need read-up about OTA Updates.
OTA is one of the main benefits of using an ESP8266 or ESP32 based device in my opinion.
You need to install Python on your PC for OTA to work, but that’s quite straightforward.
You also need to add some OTA code to your sketch, but that’s also straightforward.
Hi PeteKnight,
I will have a read as time permits, appreciate your input!
Ok thanks, I just had a read. From that I see a virtual pin is like an excel macro… i.e call macro, but the macro has a number of actions tied to it.
So in plain English I’d imagine the idea for me would be to creat a virtual pin that:
- Sets relevant pin to high turning my relay on.
- Setting a time delay of X seconds
- Setting the previous pin back to low, turning the relay off.
I’d imagine I would also have to have a start-up action to also set/keep the pin Low.
Am I on the right path?
But, as @daveblynk has already said, this needs to be a lambda Timer, not a delay()
If that’s the behaviour you want then yes. You’d do this in void setup, with a digitalWrite command immediately after your pinMode command.
Thank you!
BTW where do I begin with Lamba timer?
Googling doesn’t return a dedicated page about it.
Search this forum.
Hi, am I on the right track with this code?
Follow us: http://www.fb.com/blynkapp
http://twitter.com/blynk_app
This example runs directly on NodeMCU.
Note: This requires ESP8266 support package:
https://github.com/esp8266/Arduino
Please be sure to select the right NodeMCU module
in the Tools -> Board menu!
For advanced settings please follow ESP examples :
- ESP8266_Standalone_Manual_IP.ino
- ESP8266_Standalone_SmartConfig.ino
- ESP8266_Standalone_SSL.ino
Change WiFi ssid, pass, and Blynk auth token to run :)
Feel free to apply it to any other example. It's simple!
char pass[] = "YourPassword";
pinMode(12, OUTPUT); // Initialise digital pin 6 as an output pin (GPIO12)
Blynk.syncVirtual(V6); // will cause BLYNK_WRITE(V6) to be executed
BLYNK_WRITE(V6) // Executes when the value of virtual pin 6 changes
if(param.asInt() == 6)
// execute this code if the switch widget is now ON
digitalWrite(12,HIGH); // Set digital pin 6 (GPIO12) to HIGH
timer.setTimeout(1000L, []() { // Wait 1 second then...
digitalWrite(12,LOW); // Set digital pin 6 (GPIO12) to LOW
}); // END of Lambda Function
// execute this code if the switch widget is now OFF
Does it work?
The code compiles, but yet to test it on actual nodemcu. It’s quite late here now (Australia) and it’s a bit of effort to get to where I’ve located it, so maybe tomorrow I’ll test.
Do you see any potential issues with the code?
An update, and a fairly good one for a novice like me.
I have ended up with the below code, which seems to do exactly what I want, and together with IFTTT, I can now use “OK Google” to activate the 4 different relays exactly how I want.
I went further and set up my smartwatch with an HTTP request and can now open my gate - quite happy with that.
But I do have some questions,
What happens in the event of network disconnection mid-way between a set of actions? How can I be sure the virtual pins are always in sync with the Blynk dashboard.
If an HTTP request has been carried out, is there a snippet of code somewhere that can alert me to that via the Blynk app? - but only for HTTP requests such as the ok google/IFTTT requests and not the actions through the apps dashboard?
Is there the possibility for any other reason that the code could stop - and potentially keeping my relay always on?
The OTA function - I am struggling to find a good and relevant tutorial for this on the NodeMCU. I found one which initially sets up the SSID/pass but then I thought that was doubling up with Blynk’s own
etc - is this a conflict and do I need to remove the SSID, pass from the Blynk line?
char auth[] = "auth";
char ssid[] = "ssid";
char pass[] = "pass";
Blynk.begin(auth, ssid, pass, IPAddress(45,55,96,146), 80);
pinMode(4, OUTPUT); // Initialise NodeMCU D2 as an output pin
pinMode(12, OUTPUT); // Initialise NodeMCU D6 as an output pin
pinMode(13, OUTPUT); // Initialise NodeMCU D7 as an output pin
pinMode(15, OUTPUT); // Initialise NodeMCU D8 as an output pin
Blynk.syncVirtual(V2); // will cause BLYNK_WRITE(V2) to be executed
Blynk.syncVirtual(V7); // will cause BLYNK_WRITE(V7) to be executed
Blynk.syncVirtual(V8); // will cause BLYNK_WRITE(V8) to be executed
BLYNK_WRITE(V2) // Executes when the value of virtual pin 2 changes
if(param.asInt() == 1)
digitalWrite(4,HIGH); // Set NodeMCU D2 to HIGH
timer.setTimeout(1000L, []() { // Wait 1s then...
digitalWrite(4,LOW); // Set NodeMCU D2 to LOW
Blynk.virtualWrite(V2,0); // Turn the widget attached to V2 Off
digitalWrite(12,HIGH); // Set NodeMCU D6 to HIGH
digitalWrite(12,LOW); // Set NodeMCU D6 to LOW
Blynk.virtualWrite(V6,0); // Turn the widget attached to V2 Off
BLYNK_WRITE(V7) // Executes when the value of virtual pin 7 changes
digitalWrite(13,HIGH); // Set NodeMCU D7 to HIGH
digitalWrite(13,LOW); // Set NodeMCU D7 to LOW
Blynk.virtualWrite(V7,0); // Turn the widget attached to V7 Off
BLYNK_WRITE(V8) // Executes when the value of virtual pin 8 changes
digitalWrite(15,HIGH); // Set NodeMCU D8 to HIGH
digitalWrite(15,LOW); // Set NodeMCU D8 to LOW
Blynk.virtualWrite(V8,0); // Turn the widget attached to V8 Off
Do some testing and see what happens. If the network is disconnected then your device can’t remain synchronised with the Blynk app, as there is no communication taking place.
No, pin changes via API calls, App inputs or Bridge commands aren’t differentiated. The solution would be to set-up two different virtual pins, which perform almost identical actions and have one which is controlled from the app and another that is controlled via API calls. You can then choose what actions each BLYNK_WRITE(vPin) performs, and one of those could include a message to show that an action received via the API stream was successful.
Provided that your relays default to a ‘fail safe’ state when power is disconnected then you’ve done everything you can.
This is a good starting point:
OTA Updates — ESP8266 Arduino Core 2.7.1-110-gc1118dfc documentation
Thanks PeteKnight
Ok
I have found this snippet of code in the examples
// Invert state, since button is "Active LOW"
int isButtonPressed = !digitalRead(2);
if (isButtonPressed) {
Serial.println("Button is pressed.");
// Note:
// We allow 1 notification per 15 seconds for now.
Blynk.notify("Yaaay... button is pressed!");
I can’t wrap head around that, could you elaborate more on int isButtonPressed = !digitalRead(2);
I see that we are first declaring an integer of ‘isButtonPresses’ with the default reading being 2?
I am completely lost around this and I have even had my morning coffee.
I thought I could add some code after Blynk.virtualWrite such as
Serial.println("Device activated by Smartwatch");
Blynk.notify("Device activated by Smartwatch");
Doing this shows up the text in the serial monitor, but I don’t get a push notification. I have reinstalled the app and ensured the app has full access to android notifications and can override Do Not Disturb etc. Can I do it this way?
- All good then, that will happen.
- Perfect - great article, done in 5 mins.
Thanks for you guidance.
I have no idea how this relates to your question, but here here goes…
This is basically saying “set the integer variable isButtonPressed to the opposite of the result that you get when you do a digital read on pin GPIO2”
The exclamation mark operator “!” means NOT, which is effectively saying “the opposite of”, so if digitalRead(2)
returns HIGH then the result od applying a NOT operator will be LOW (or 0 as it’s an integer).
Do you have the Notification widget in the app?
Have you tested doing an OTA upload?
Essentially, I found this code from the Blynk example browser
void notifyOnButtonPress()
// Note:
// We allow 1 notification per 5 seconds for now.
// You can also use {DEVICE_NAME} placeholder for device name,
// that will be replaced by your device name on the server side.
//Blynk.notify("Yaaay... {DEVICE_NAME} button is pressed!");
But I don’t really understand it and why/if I would need to set it up in this format, it truly isn’t sinking in.
So, in plain language, this code is saying if the button is pressed (reading a high) then the integer value of isButtonPressed will read 0? Then the next line of code appears to be an if statement, but I don’t see a typical “if this is true then that” type of argument that follows.
I am sorry, I can’t understand logically how this code is playing a role to push an in-app notification?
As I now have separated the BLYNK_WRITE Codes, I am wondering why I couldn’t add the “Blynk.notify” statement as per the following code?
BLYNK_WRITE(V21) // Executes when the value of virtual pin 21 changes (By Smartwatch)
Blynk.virtualWrite(V21,0); // Turn the widget attached to V21 Off
Serial.println("Spare Relay activated by Smartwatch");
Blynk.notify("Spare Relay activated by Smartwatch");
Yes I do, with the following settings
- Notify when hardware goes offline - Set to ON (and I do get those ones)
- Offline ignore period - set to 1 min
- Priority - High
Yes, worked well.
