My projects are for greenhouse and irrigation in rural area so Internet connectivity.
We use ESP32 T-Call and RPI with 2G Modem.
Thus we required Automation(at least partially) which can work even if the connection is down or interrupted. I think to be fully automated for cross devices are not possible.
Yes, our controller need to check the sensor data every 5 minutes, we have around 8 sensors
It also includes 4 relays and also serve as controller for another 8 relay connected to it thru Tasmota.
http://twitter.com/blynk_app
This example shows how to keep WiFi connection on ESP8266.
/* Fill-in your Template ID (only if using Blynk.Cloud) */
//#define BLYNK_TEMPLATE_ID "YourTemplateID"
char pass[] = "YourPassword";
int lastConnectionAttempt = millis();
int connectionDelay = 5000; // try to reconnect every 5 seconds
// check WiFi connection:
if (WiFi.status() != WL_CONNECTED)
// (optional) "offline" part of code
// check delay:
if (millis() - lastConnectionAttempt >= connectionDelay)
// attempt to connect to Wifi network:
if (pass && strlen(pass))
WiFi.begin((char*)ssid, (char*)pass);
WiFi.begin((char*)ssid);
