Off line too ofthen
may be i don’t write the code in the right way or may be i m not lucky but my blynk goes to many times offline wile i m connected
this is my code could you please help me and tell me what is wrong?
in my sketch Esp8266 communicate via Wire protocol to an arduino and just gives to arduino 1 byte
could you help me?
//#define BLYNK_PRINT Serial    // Comment this out to disable prints and save space
#include <Wire.h>
#define I2CAddressESPWifi 6
char auth[] = "666833b5703b49d097c7ca9f03e3a8c2";
#define ZoneUp  V4
#define ZoneDown V3
#define DELAY            10  // Delay per loop in ms
boolean up_was_pressed; // previous state
boolean down_was_pressed; // previous state
unsigned long interval = 3000;  // the time we need to wait
unsigned long previousMillis=0; // millis() returns an unsigned long.
int HR;
int Amp;
int Batt;
int Watt;
int RPM;
int Speed;
int TWatt;
int Th;
int Zone;
int HRWatt;
byte a, b, c, d, e, f, g;
  Wire.begin(14,12);//Change to Wire.begin() for non ESP.
  Zone = 0;
 //Blynk.begin(auth, "S&S", "02011964");
  Blynk.begin(auth, "iPhone di Simone", "downdown");
if (Zone < 0) {Zone = 0;}
if (Zone > 4) {Zone = 4;}
if (Watt > 200) {Watt = 0;}
if (HR > 220) {HR = 0;}
if (Speed > 100) {Speed = 0;}
if (Batt > 100) {Batt = 0;}
 if ((unsigned long)(millis() - previousMillis) >= interval) {
      previousMillis = millis();
   Blynk.virtualWrite(V0, HR);
   Blynk.virtualWrite(V1, Watt);
 if (Zone == 0) {Blynk.virtualWrite(V2, "Free");}
   if (Zone == 1) {Blynk.virtualWrite(V2, "Eco");}
      if (Zone == 2) {Blynk.virtualWrite(V2, "Tour");}
         if (Zone == 3) {Blynk.virtualWrite(V2, "City");}
            if (Zone == 4) {Blynk.virtualWrite(V2, "HWRS"); }
   Blynk.virtualWrite(V5, Speed);
   Blynk.virtualWrite(V6, Batt);
   Trasmission();
   Request();
BLYNK_WRITE(ZoneUp)
  if (param.asInt()) Zone = Zone + 1; //else lightoff();
BLYNK_WRITE(ZoneDown)
  if (param.asInt()) Zone = Zone - 1; //else lightoff();
void Trasmission()
  byte myArray[1];
  myArray[0] = Zone;
  Wire.beginTransmission(I2CAddressESPWifi); // transmit to device #8
  Wire.write(myArray,1);         // sends one byte
  Wire.endTransmission();    // stop transmittin
  delay(1);
void Request()
 Wire.requestFrom(I2CAddressESPWifi, 7);
  if (Wire.available())
  delay(1);
   a = Wire.read();
   b = Wire.read();
   c = Wire.read();
   d = Wire.read();
   e = Wire.read();
   f = Wire.read();
   g = Wire.read();
   HR = a;
   Batt = b;
   Watt = c;
   Watt = (Watt << 8) | d;
   Speed = e;
   RPM = f;
   HRWatt = g;
  Serial.print("HR ");
  Serial.print(HR);
  Serial.print(" : Batt ");
  Serial.print(Batt);
  Serial.print(" : Watt ");
  Serial.print(Watt);
  Serial.print(" : Zone ");
  Serial.print(Zone);
  Serial.print(" : HRWatt ");
  Serial.print(HRWatt);
  Serial.print(" : Speed ");
  Serial.print(Th);
  Serial.print(" : RPM ");
  Serial.print(RPM);
  Serial.println("]");
 //delay(500);
Please use formatting “</>” button. It hard to read your code.
i tryed but i don’t understand how…
now i understood
Please enable debug and post result here.
[4213] Connected to WiFi
[4213] My IP: 192.168.1.143
[4213] Blynk v0.3.3-beta
[5001] Connecting to cloud.blynk.cc:8442
[10002] Connecting to cloud.blynk.cc:8442
[10455] Ready (ping: 1ms).
[22110] Connecting to cloud.blynk.cc:8442
[22522] Ready (ping: 2ms).
[32015] Connecting to cloud.blynk.cc:8442
[32324] Ready (ping: 14ms).
[70090] Connecting to cloud.blynk.cc:8442
[70497] Ready (ping: 3ms).
Does your ESP works fine without Blynk? Please try to narrow down your problem. For instance, try to comment out
   Trasmission();
   Request();
