Numeric Input Widget
I am using a Numeric Input Widget. The settings set are from 0% to 100%. The suffix is “%”. It has also been set to loop values. The step increment is set to 1.
The issue when running if you push the + or - buttons it works fine meaning the number progress in sigle units. When it comes to say 100 and you press + you get 0.00000 instead of just 0. Is there any way to change this so that it shows just 0. This widget does not have the option of hiding/showing the decimal point as others widgets do.
same issue for me since the beginning.
But with the last release it seems perfect .
before update
Video_2019-06-13_195645
and now
Video_2019-06-13_194750
What release do you have?
I have 0.6.1
blynk app not library
last 2.27.6 beta
Strange normally the phone always updates I will try uninstalling and re install
I use android beta version, not the public version.
update 2 or 3 days ago.
Ah Ok.
