Numeric Input widget (not stepping by 0.5)
Like Blynk_Coeur (March 4), I cannot increment the value with the step defined in the Numeric Input Settings. I’m trying to increment by 0.5, but it always increments by 1.
The the relevant data stream settings for that virtual pin are
  • Data type: Double
  • Decimals: #.#
  • Units: Celsius
This widget worked well in an earlier version of the mobile App that I created with Blynk 1. This is a new problem for me on Blynk IOT (Blynk 2).
I also tried changing the step to 2, but it would still only step up or down by the value of 1.
Am I missing a setting?
Jake
Not solved at the moment, we have to wait next app update
It will be fixed this week.
Thanks. Look forward to the fix.
In the meantime, I was able to make do with the Step Slider widget which also allows for the stepping of values includings steps involving decimal numbers.
The issue has been solved, numeric input widget is working properly now.
Thank you @BlynkAndroidDev
