I try Text Input but it also allows the alphabet to enter.
Numeric Input is not good for long numbers entered as + and - there
I need an input field where only a number can be inputted. Only a numeric keyboard will open if I click on that field.
Thanx : )
Hi @Texe07 ,
In the “Numeric Input” widget you can enter a value via the keyboard by clicking on the input field.
Dmitriy from Blynk
try the numeric input field it only ends on 999999999. How to put the Phone number there as its 10 digit number.?
Thanx : )
The largest number you can enter depends on your datastream, but 4294967296 will be the largest number you can enter, because that’s the largest 32-bit integer. That makes it unsuitable for phone numbers.
You’d be better to use a text input field then do some validation on the text.
