I am having a problem similar to this. The sensor readings are being sent to Blynk over bluetooth and are updating every 15 seconds. I’m trying to use the webhook to update thingspeak every 30 seconds. The number of entries increase on Thingspeak as I want but the values aren’t being displayed on the graphs.
This is the code I have and how I’ve set up the webhook:
DHT dht(DHTPIN, DHTTYPE);
SerialBLE.begin(9600);
Blynk.begin(SerialBLE, auth);
dht.begin();
// Setup a function to be called every 5 second
timer.setInterval(10000, sendSensor);
timer.setInterval(10000, sendLDR);
timer.setInterval(30000, SendtoThingspeak);
void sendSensor()
float h = dht.readHumidity();
// Write DHT22 values to Blynk
Blynk.virtualWrite(V4, h);
Blynk.virtualWrite(V5, t);
void sendLDR()
float ldr = analogRead(ldr);
// Write LDR values to Blynk
Blynk.virtualWrite(V6, ldr);
void SendtoThingspeak()
Blynk.virtualWrite(V3, t, h, ldr);
When I change /pin[0]/ to an actual value, that value will be displayed on the thingspeak graph.
I’ve been trying to figure this out for a couple of weeks and really need help.
Thanks in advance!!
Please don’t tack new issues into older topics. I moved your post into its own topic.
That is because the API URL needs an actual value, it is a Web browser like process and not meant to work with variables, at least directly like that.
You would need to first build up a String using text and data variables and then use that completed String as the final URL. I do not have any handy examples, sorry.
Thanks for replying!
So what you’re saying is that I must create a separate string for all the different sensors and then update the URL so that it looks like this:
http://api.thingspeak.com/update?api_key=XXXXXXXXX&field1=string t&field2=string h
I have added that to my code so i know looks like this
// create ble serial instance
SoftwareSerial SerialBLE(10, 11); // Rx, Tx
#define DHTPIN 13 // Pin DHT22 is connected to
#define ldrPIN A0 // Pin LDR is connected to
#define DHTTYPE DHT22 // DHT 22
float t;
float h;
float ldr;
dht.begin();
if (client.connect(server,80)) { // "184.106.153.149" or api.thingspeak.com
String postStr = 1CO81IDJXVZVGRDV;
postStr +="&field1=";
postStr += String(t);
postStr +="&field2=";
postStr += String(h);
postStr +="&field3=";
postStr += String(ldr);
postStr += "\r\n\r\n";
client.print("POST /update HTTP/1.1\n");
client.print("Host: api.thingspeak.com\n");
client.print("Connection: close\n");
client.print("X-THINGSPEAKAPIKEY: "1CO81IDJXVZVGRDV"\n");
client.print("Content-Type: application/x-www-form-urlencoded\n");
///client.print("Content-Length: ");
/// see https://community.thingspeak.com/forum/announcements/sending-data-to-thingspeak-api-from-device-but-channel-is-not-updated-what-changed/#p7929
///client.print(postStr.length());
client.print(String(postStr.length()));
client.print("\n\n");
client.print(postStr);
timer.setTimeout(200L, []() { // Lambda Reconnection Timer Function activating once in 200 milliseconds
yield();
client.stop();
} ); // END Timer Function
void sendSensor()
void sendLDR()
// Write LDR values to Blynkd
I’m getting errors that client and server aren’t delcared. Sorry if this is a stupid question, I’m not good a coding, but what do I delcare client and server as?
I am not able to debug your sketch right now, but from my very fast observation I saw that you missed:
#include <ESP8266WiFi.h;
WiFiClient client;
The above should be written before
void setup() { …
ALSO MOVE THINGSPEAK UPDATES OUT OF loop. You can not update these values so much often, needed to pout in a timer function and to activate each let’s say 20 seconds ( 20000L timer value ).
