Please use back ticks to format your code in the future. If you can’t find them google them for your OS. Are you using an iPhone by the way? I had to reinstall my app for the notifications to start working again…
All I can say is I have three different Android devices, two phones and one tablet, that are running 27/7 and each will get notifications… although admittedly my daily driver phone, a LG G6, gets them usually immediately, but sometimes many minutes later and every once in awhile hours later … I can only attribute this to either the phone and/or OS skin it uses. And my one iOS device will rapidly bleep all past notifications once it turns on… very annoying
To send the Developers the logs from your App press the upper left icon as if to change projects, then the upper right [i] icon and Send logs to developer
It is just a current version of the App but with much more logging included so that the developers can hopefully understand the hows, whys and wheres of some user issues.
You seem to still be running an older version of the App… you should be seeing a screen like this…
What is interesting is that whatever action I did in Blynk is always the same log, for example, added a Button widget and changed the state of a pin on arduino, which was not reflected in the logs.
After clicking on Send logs to developer, a menu appears where I have to select the program with which the report will be sent. Has the question report already been sent or is it still necessary to choose a program to send?
