Not reaching ping
I am using uno with esp8266
Wifi gets connected but It doesn;t reach ping and it gets stuck in between like this.
@Pavel @Dmitriy @Costas @Lichtsignaal
Try 0.3.7 and see what results you get.
I did. Got the same results
But you shouldn’t be using 0.3.4 at all.
The libraries before 0.3.5 should fail as they were for the old server so don’t waste time even trying.
Please provide your sketch now you have the correct libraries.
i have just connected the esp to uno. normal connections nothing more. this is the code
#include <ESP8266_Lib.h>
char auth[] = "";
//#define EspSerial Serial1
// Your ESP8266 baud rate:
#define ESP8266_BAUD 9600
ESP8266 wifi(&EspSerial);
  // Set console baud rate
  // Set ESP8266 baud rate
Blynk.begin(auth, wifi, "net_9718015549call", "macbeth123" );
  //Blynk.begin(auth, wifi, "ssid", "pass");
  //Serial.println(AT+CIPSTART= “TCP” , “blynk-cloud.com”, “8080”);
I am getting no where. Please help @Dmitriy @vshymanskyy @Pavel @Lichtsignaal
i am having the same problem…did you figure it out?
This is a year old topic!!.. Please don’t reopen them with “Me Too” issues… look at the solved ones.
