I did not find similar topics;
• Hardware: ESP8266 NodeMCU Lolin V3;
• Smartphone OS: Android 7 (Samsung, J5 Pro);
• Blynk server: Cloud;
• Blynk Library version: 2.24.0;
My problem is:
I can run and connect to the application. But if I reset the module (ESP) both the Serial Monitor and the app stop receiving the date and time data (no connection or event ever occurs). The system locks completely and only returns when the code is rewritten in ESP.
Would anyone know what the problem is? I really need this project to have no problems getting and keeping date and time, as it is a datalogger and I have had many problems with physical (hardware) RTCs.
Thank you.
My sketch code:
http://twitter.com/blynk_app
Blynk can provide your device with time data, like an RTC.
Please note that the accuracy of this method is up to several seconds.
App project setup:
RTC widget (no pin required)
Value Display widget on V1
Value Display widget on V2
WARNING :
For this example you'll need Time keeping library:
https://github.com/PaulStoffregen/Time
This code is based on an example from the Time library:
https://github.com/PaulStoffregen/Time/blob/master/examples/TimeSerial/TimeSerial.ino
#include <TimeLib.h>
#include <WidgetRTC.h>
char auth[] = "***************";
char ssid[] = "***************";
char pass[] = "***************";
WidgetRTC rtc;
// Digital clock display of the time
void clockDisplay()
// You can call hour(), minute(), ... at any time
// Please see Time library examples for details
Serial.print(currentTime);
Serial.print(" ");
Serial.print(currentDate);
Serial.println();
// Send time to the App
Blynk.virtualWrite(V5, currentTime);
// Send date to the App
Blynk.virtualWrite(V6, currentDate);
// Begin synchronizing time
rtc.begin();
// Other Time library functions can be used, like:
// timeStatus(), setSyncInterval(interval)...
// Read more: http://www.pjrc.com/teensy/td_libs_Time.html
// Display digital clock every 10 seconds
timer.setInterval(5000L, clockDisplay);
