I am very new to Blynk. I am using an HC-05 with an Arduino UNO. I am able to turn a led on and off via Bluetooth from the app. I want to send an email to my gmail when the out put of a certain function is 1. I have followed the sketch, but it is not sending anything. Could you please help me.
this is my sketch:
#include <ADXL335ACC.h>
ADXL335ACC accelerometer ;
/* Set this to a bigger number, to enable sending longer messages */
//#define BLYNK_MAX_SENDBYTES 128
char auth[] = "92e9e80812e7495ead72da9315b1e5d7";
SoftwareSerial SerialBLE(10, 11); // RX, TX
unsigned count = 0;
int i=0;
SerialBLE.begin(9600);
Blynk.begin(SerialBLE, auth);
accelerometer.Begin();
if (accelerometer.IsFreeFall() == 1){
Blynk.email("subject :Fall detected ", "your randma/grandpa has fallen"); }
Notification group of widgets would not work on Bluetooth/BLE connection in almost all cases, as it means that the hardware is not connected to the Internet, so email, push notifications, twitter widgets would not work in such environment. On several latest versions of Android app it could work, but only in the case of persistent Bluetooth/BLE connection between smartphone and hardware.
Thanks for the help. apparently now that I did some modifications, it is trying to send the email but, it is saying. you need to update the app. It’s outdated.
#include <Blynk.h>
BlynkTimer Timer; // Announcing the timer
void CheckIsFreeFall()
Timer.setInterval(250L, CheckIsFreeFall); //timer will run every sec
Blynk.email("idir.mahrouche@gmail.com", "subject :Fall detected ", "your randma/grandpa has fallen");
Blynk.notify("ESP8266 Alert - Temperature over 28C!");
Blynk.run(); // run Blynk magic
Timer.run(); // run timer every second
App’s version? If the 2.27.0 - join the beta and download 2.27.1 - reproduce your issue with this error, and open Blynk app’s About screen, select ‘Send logs’ option on it - send email with the log file to alex@blynk.cc
