Using blynk app.
Installed blink server on my Raspi.
Crrated an account to the server on my app using customer server ip.
Created a simple project xyz
Token is provided in my sketch to nodeMCU.
Uploaded the sketch.
Blynk server in my raspi is up and running.
Only issue is that when i run the project in Blynk app, project is seen as ‘wasn’t online yet’
Just want to find out the mistake i make here
What Blynk connection parameters are you using in your sketch? (In other words, what does your Blynk.begin command look like?)
What does your NodeMCU serial monitor show?
Thanks a lot for your reply.
Connection Parameters are like this. credentials I gave correctly.
char auth[] = "puIrKAfCGP6Oue6IxkuwHgEi12XbL5yM";
char ssid[] = "xxxxxxxxx";
char pass[] = "xxxxxxxx";
Blynk.begin(auth, ssid, pass,"192.168.1.28");
Serial Monitor Shows like below:
[3643868] Connecting to 192.168.1.28:80
[3648869] Connecting to 192.168.1.28:80
[3653870] Connecting to 192.168.1.28:80
[3658871] Connecting to 192.168.1.28:80
@SATHIAN please edit your post, using the pencil icon at the bottom, and add triple backticks at the beginning and end of your code so that it displays correctly.
I edited. Hope I did it correctly
No. I gave you triple backticks so tat you could copy/paste them, and you used some other characters instead.
Sorry!.. Corrected it now.
thanks. Hopefully you can read it well now.
I would change this to:
Blynk.begin(auth, ssid, pass,"192.168.1.28", 8080);
Thanks a lot!! It Worked!!!
It saved a lot of my time!!
