Is this topic solved then?
As for other issues/questions, aside from searching this forum and reading the docs… make another topic so others can see the details and help with the API stuff (but simple answer is yes… if done properly
That page is just a demo and documentation… you will use the actual API command in a web browser or even in the Webhook Widget for cross-project data/command sharing.
