I am trying to replicate a temp anywhere project I found on instructables:
I got the authors instruction on Dallas Temp and one wire loaded and checked that I was getting temp readings using serial monitor.
Now I am supposed to load the author’s TempMonBlynkExt.ino zip file but I can’t figure out how to do this. I have asked several questions on the instructable and I do not think it is being monitored or perhaps he is too busy.
Could anyone give me a step by step? This is my first Blynk and I would like to see it work.
Thanks in advance,
Dave
age 67 and still trying
Welcome to the Blynk Forum… Step by step instructions are not as simple as it seems… to much depends on your overall knowledge of Arduino, some programming, hardware, etc.
I highly recommend you try out the Help Center to get started learning Blynk… then try a few simple examples from the Sketch Builder and don’t forget the Documents page.
Then once you have a better handle on the basics, installing the files from that Instructable will make more sense.
And as you go along… feel free to ask for any clarifications with commands and such.
Never stop trying
I don’t see a zip file for the ino sketch. It’s a plain text file containing this sketch:
* IoT Temperature Monitor with Blynk
* Developed by Marcelo Rovai - 05 January 2017
/* ESP & Blynk */
char auth[] = "YOUR AUTH CODE HERE";
/* WiFi credentials */
char ssid[] = "YOUR SSID";
char pass[] = "YOUR PASSWORD";
/* TIMER */
/* DS18B20 Temperature Sensor */
#include <OneWire.h>
#include<DallasTemperature.h>
#define ONE_WIRE_BUS 2 // DS18B20 on arduino pin2 corresponds to D4 on physical board
DallasTemperature DS18B20(&oneWire);
float temp;
DS18B20.begin();
timer.setInterval(1000L, getSendData);
* Send Sensor data to Blynk
void getSendData()
DS18B20.requestTemperatures();
temp = DS18B20.getTempCByIndex(0);
Serial.println(temp);
Blynk.virtualWrite(10, temp); //virtual pin V10
Are you able to cut and paste this into your IDE?
Have you configured your IDE for use with ESP’s or is it just set up for flashing Arduino’s?
Thank You Gunner, I intend to do that but right now I am prepping to go on a trip in 2 weeks and I want to get this up and running to keep an eye on my freezer.
Thank You Costas,
I said zip b/c when I downloaded the ino file to my pc it was a zip.
I did the whole first five steps of the instructible and got temp readings to run using the serial monitor so I got all that to work. IDE must be ok for ESP,
3.So when I paste the text I should go ahead and put my token where it says authorization code, and the same with my network info? Do I use quotes?
4.I did a trial without entering the #3 items above and got an exit status 1 #include expects “FILENAME”
UPDATE: I found on another forum a guy with the same issue and he was told to just delete the #include, so I did that, please tell me if that is wrong. I then compiled and got:Arduino: 1.8.3 (Windows 10), Board: “NodeMCU 1.0 (ESP-12E Module), 80 MHz, 115200, 4M (3M SPIFFS)”
sketch_aug24a:11: error: unable to find numeric literal operator ‘operator"" a94038a814044b1077308f478a1c1’
char auth[] =328a94038a814044b1077308f478a1c1
I must be inputting info incorrectly.
I think with just a little nudge I can get this and I do promise I will learn this correctly when we get back from our trip.
Thanks,
Dave
below is the full error report, I x’d out my network password for posting:
Arduino: 1.8.3 (Windows 10), Board: "NodeMCU 1.0 (ESP-12E Module), 80 MHz, 115200, 4M (3M SPIFFS)"
sketch_aug24a:11: error: unable to find numeric literal operator 'operator"" a94038a814044b1077308f478a1c1'
sketch_aug24a:15: error: 'oxxxxxx0' was not declared in this scope
char pass[] =oxxxxxxx0;
sketch_aug24a:18: error: 'SimpleTimer' does not name a type
sketch_aug24a:23: error: 'OneWire' does not name a type
sketch_aug24a:24: error: 'DallasTemperature' does not name a type
C:\Users\longb\Downloads\sketch_aug24a\sketch_aug24a.ino: In function 'void setup()':
sketch_aug24a:30: error: 'Blynk' was not declared in this scope
sketch_aug24a:30: error: 'ssid' was not declared in this scope
sketch_aug24a:31: error: 'DS18B20' was not declared in this scope
DS18B20.begin();
sketch_aug24a:32: error: 'timer' was not declared in this scope
C:\Users\longb\Downloads\sketch_aug24a\sketch_aug24a.ino: In function 'void loop()':
sketch_aug24a:37: error: 'timer' was not declared in this scope
sketch_aug24a:38: error: 'Blynk' was not declared in this scope
C:\Users\longb\Downloads\sketch_aug24a\sketch_aug24a.ino: In function 'void getSendData()':
sketch_aug24a:46: error: 'DS18B20' was not declared in this scope
sketch_aug24a:49: error: 'Blynk' was not declared in this scope
sketch_aug24a:51: error: redefinition of 'void setup()'
sketch_aug24a:27: error: 'void setup()' previously defined here
sketch_aug24a:56: error: redefinition of 'void loop()'
sketch_aug24a:35: error: 'void loop()' previously defined here
exit status 1
Yes, yes and yes.
You can’t delete the #include entries.
If it’s not working paste your code.
I’m here at my pc , I have gone back to the instructable and re copied his code to make sure it is clean and un messed with and I’m opening a new pj in IDE.
Pasted his code and put my token in the quotes as well as my ssid and pw, all in quotes.
I’m getting this error that #include wants a “FILENAME”
Here is the paste of the error:
sketch_aug24a:10: error: #include expects "FILENAME" or <FILENAME>
#include
sketch_aug24a:11: error: #include expects "FILENAME" or <FILENAME>
#include
sketch_aug24a:20: error: #include expects "FILENAME" or <FILENAME>
#include
sketch_aug24a:24: error: #include expects "FILENAME" or <FILENAME>
#include
sketch_aug24a:25: error: #include expects "FILENAME" or <FILENAME>
#include
exit status 1
This is the authors original code:
/* ESP & Blynk */
#include
#include
/* TIMER */
#include
#include
#include
float temp;
DS18B20.begin();
void getSendData()
I’LL stay right here for the next hour with it all plugged in if that helps
THANK YOU
It’s because the libraries don’t show correctly with instructables or here of you don’t format the post correctly.
Try the code below but put your credentials in it:
/* ESP & Blynk */
/* TIMER */
//#include <SimpleTimer.h> // NOT REQUIRED WITH BLYNK LIBRARY VERSION 0.4.8 AND BEYOND
float temp;
DS18B20.begin();
void getSendData()
Did that, eprhaps I pasted it in the wrong place? I pasted right at the top, I’m just guessing.
Here is the error report:
C:\Users\longb\Downloads\sketch_aug24a\sketch_aug24c\sketch_aug24c.ino: In function 'void setup()':
sketch_aug24c:56: error: redefinition of 'void setup()'
sketch_aug24c:31: error: 'void setup()' previously defined here
C:\Users\longb\Downloads\sketch_aug24a\sketch_aug24c\sketch_aug24c.ino: In function 'void loop()':
sketch_aug24c:61: error: redefinition of 'void loop()'
sketch_aug24c:39: error: 'void loop()' previously defined here
exit status 1
What I provided is the full sketch, paste over the top of any other code you have. Then enter your token and WiFi details.
You are a Blynk HERO
Thank you, thank you, is there some way I can give you points or something?
I did mark all your help with a like.
And how do I mark this a solved?
I replicated a pj I found on instructibles for wifi temp:
Got it all up and running well but want to have the temp readings in F not C
Tried to do it myself by changing the C in the below to F:
Now I get readings in F but they are pretty slow to react (20secs) and Blynk keeps reconnecting to the server.
Should I have made other changes to the code?
/* ESP & Blynk */
/* TIMER */
float temp;
DS18B20.begin();
void getSendData()
Thanks in advance, I know I need to start learning this properly, but today I am on a 2 week deadline to get a monitor running for our chest freezer before we go on a trip.
Dave
@David_Vinch is V10 a display widget and have you changed the default READING RATE from “1 sec” to “PUSH”? It should update at 1 second intervals from the setInterval of 1000ms in your sketch. Something not right if it’s taking 20 seconds.
It could be your error with the READING RATE because ESP’s get confused if they are being pulled by the app and pushed by the sketch. One or the other, not both.
Thanks for your suggestion, I’m going to keep a copy in my pj folder and look into it. Apparently the problem I was experiencing this AM was not code related at all, This afternoon all is fine, and again this evening. Just one of those things.
Display is a gauge and a graph.
Same thing applies to a gauge, default is 1sec and you must change to PUSH.
O.K. Thanks.
I second this…
Even though I only used virtual pins… and even went as far as adding in this line…
#define BLYNK_NO_BUILTIN // Disable built-in App <--> Analog & Digital pin operations
…to my script, I was chasing reliability issues. Then thanks to @Costas, I realised I had about half my displays (of various types) set to the default 1sec… once I switched them all to PUSH, everything was fine.
Did as instructed Thanks.
Hi Folks, I just wanted to check in again. The author made another instructible to up the project to two sensors and since that was my original intention I went ahead. I had a lot of compilation issues until I replaced his simple timer with the blynk timer that Costas used in his rework. Now it is up and running I am getting temps on both sensors, using both gauge and history graph for both.
I am still using PUSH as instructed but again seeing those pesky reconnects, but temp updates are basically o’k’ for response. My intent here is just to monitor freezer temps so I don’t really need instant responses just need to know that it hasn’t shut down and spoiling all my put asides for the winter months. LOL what led to this was last year that did happen all that hard work went in the trash.
V10 handles one and V11 the other. Anyway here is a paste of the code:
* IoT Multiple Temperature Monitor with Blynk
* Multiple OneWire Sensor: DS18B20
* Developed by Marcelo Rovai - 25 August 2017
/* ESP & Blynk */
char auth[] = " token here";
char ssid[] = "router identity";
char pass[] = "network password";
/* TIMER */
int temp_0;
int temp_1;
DS18B20.begin();
Serial.println(" ");
Serial.println("Testing Dual Sensor data");
void getSendData()
temp_0 = DS18B20.getTempFByIndex(0); // Sensor 0 will capture Temp in Celcius
temp_1 = DS18B20.getTempFByIndex(1); // Sensor 0 will capture Temp in Fahrenheit
Serial.print("Temp_0: ");
Serial.print(temp_0);
Serial.print(" oF . Temp_1: ");
Serial.print(temp_1);
Serial.println(" oF");
Blynk.virtualWrite(10, temp_0); //virtual pin V10
Blynk.virtualWrite(11, temp_1); //virtual pin V11
If you see anything amiss give me a shout.
Thank You for making this project a reality and I do put my money where my mouth is, I’m making a contribution to Blynk.
Regards,
Dave
You have these declared twice in your sketch which will normally stop compilation so I have removed the first set from your sketch.
Also I think temp_0 and temp_1 should be float not int. So 24.7 degrees not 24 degrees. Unless you have removed most of the useful resolution of the DS18B20’s.
