Nodered свежий, ноды свежие. Текст задается в ноде Template и отправляется в Телеграм и Блинк. В Телеграме все отлично, то же самое сообщение в терминале на смартфоне с андроидом - ерунда вместо русского.
It seems that there’s an issue with the way that non-western (latin) characters are sent from Node-Red to Blynk, or in the way that they are handled when they arrive in Blynk via the websockets api.
@gab.lau, I think this is one for you in the first instance…
If I set-up an inject node to inject the text “Привет, мир” ("Hello World in Russian, according to Google Translate) then it appears correctly in the debug monitor, but not in either a Blynk Terminal or Labelled Value widget:
I personally use Blynk.virtualWrite (… ) and solved the problem of the CYRILLIC alphabet to display on the terminal. Our UKRAINIAN friends, the creators of Blynk, advised us to do just that !!!
