Try removing this line:
and move these lines below the Blynk libraries.
It is still same
23:45:29.064 -> pm open,type:2 0
23:46:40.454 -> state: 5 -> 2 (2a0)
23:46:40.454 -> rm 0
23:46:40.454 -> pm close 7
23:46:41.480 -> reconnect
23:46:41.480 -> state: 2 -> 0 (0)
23:46:41.571 -> scandone
23:46:41.571 -> no UniMAP-WiFi found, reconnect after 1s
23:46:41.663 -> reconnect
23:46:44.549 -> scandone
23:46:44.549 -> state: 0 -> 2 (b0)
23:46:44.549 -> state: 2 -> 3 (0)
23:46:45.529 -> state: 3 -> 0 (4)
23:46:45.529 -> reconnect
23:46:48.372 -> scandone
23:46:48.372 -> state: 0 -> 2 (b0)
23:46:48.419 -> state: 2 -> 3 (0)
23:46:48.419 -> state: 3 -> 5 (10)
23:46:48.419 -> add 0
23:46:48.419 -> aid 1
23:46:48.419 -> cnt
23:46:58.434 -> pm open,type:2 0
Try one of the basic sketches from the Sketch Builder, and test it with nothing connected to your board other than the USB cable.
Hi Pete, I tried the basic coding as below and use another USB cable
http://twitter.com/blynk_app
This example runs directly on ESP8266 chip.
Please be sure to select the right ESP8266 module
in the Tools -> Board menu!
/* Fill-in your Template ID (only if using Blynk.Cloud) */
//#define BLYNK_TEMPLATE_ID "YourTemplateID"
char auth[] = "y67ppUqAduYLCfRuwltVPb7mgV-lulsa"; // Authentication Token Sent by Blynk
char ssid[] = "Carvell"; //WiFi SSID
char pass[] = "carvell1234"; //WiFi Password
The serial monitor show
Can you post a screenshot of your phone’s WiFi connection screen, which shows the WiFi SSID that your phone is connected to?
To connect with blynk cloud instead of using
use
Blynk.begin(auth, ssid, pass, “blynk.cloud”, 80);
@Priyank_Raj your comment isn’t relevant to this topic, but your solution shouldn’t be required for any sketch provided that the Blynk 1.0.1 library is being used, and the firmware configuration settings have been copied from the Blynk web console and pasted at the very top of the sketch.
