Esp is not responding. I am using a NodeMCU ESP8266 with a mega Arduino. I have flashed my esp with different firmware but communication is not possible.
Do you really think that people will be able to help you based on the information you’ve provided?
Why not start by filling-in the blanks in the information you were asked to provide initially…
Before creating the topic
- Search forum for similar topics
- Check http://docs.blynk.cc and http://help.blynk.cc/
- Add details :
• Blynk Library version
• Add your sketch code.Code should be formatted as example below.
void loop()```
Providing some specific details on the firmware that you’ve flashed to the NodeMCU would also be useful, along with details of how you’ve wired your two boards together.
