Hi everybody, I’m a new member ^^. I’m trying to do “Smart Gardening” project with NodeMCU ESP8266 UART CH340 and Blynk app. I have a problem when I use VirtualPin instead of DigitalPin to control 4 relays. I can connect to NodeMCU and control with Blynk app after uploading code, but when I unplug a usb cable and plug 5V power or plug again usb cable to laptop, relay4 ON and I can’t use Blynk to control, it shows that NodeMCU is disconnected. I connected 4 relay to GPIO2, GPIO12-14. How can I fix this issue ? Here’s my code :
#include <Wire.h>
#define relay1 D6
#define relay2 D7
#define relay3 D5
#define relay4 D4
char auth[] = "jWkG2JD7zD0bjWG_fcRK4jstZVmdAPTW";
char ssid[] = "PhanLong";
char pass[] = "Long123456";
LiquidCrystal_I2C lcd(0x27,20,4);
BLYNK_CONNECTED(){
Blynk.syncAll();
BLYNK_WRITE(V10) {
int pumpstat = param.asInt();
digitalWrite(relay1,pumpstat);
if(pumpstat == 0){
lcd.setCursor(8,0);
lcd.print("OFF");
else{
lcd.setCursor(8,0);
lcd.print("ON ");
BLYNK_WRITE(V11) {
int relay1stat = param.asInt();
digitalWrite(relay2,relay1stat);
if(relay1stat == 0){
lcd.setCursor(8,1);
lcd.print("OFF");
else{
lcd.setCursor(8,1);
lcd.print("ON ");
BLYNK_WRITE(V12) {
int relay2stat = param.asInt();
digitalWrite(relay3,relay2stat);
if(relay2stat == 0){
lcd.setCursor(8,2);
lcd.print("OFF");
else{
lcd.setCursor(8,2);
lcd.print("ON ");
BLYNK_WRITE(V13) {
int relay3stat = param.asInt();
digitalWrite(relay4,relay3stat);
if(relay3stat == 0){
lcd.setCursor(8,3);
lcd.print("OFF");
else{
lcd.setCursor(8,3);
lcd.print("ON ");
pinMode(relay1,OUTPUT);
pinMode(relay2,OUTPUT);
pinMode(relay3,OUTPUT);
pinMode(relay4,OUTPUT);
digitalWrite(relay1,LOW);
digitalWrite(relay2,LOW);
digitalWrite(relay3,LOW);
digitalWrite(relay4,LOW);
lcd.begin();
lcd.backlight();
lcd.setCursor(0,0);
lcd.print("BOM :");
lcd.setCursor(0,1);
lcd.print("MODE 1 : ");
lcd.setCursor(0,2);
lcd.print("MODE 2 : ");
lcd.setCursor(0,3);
lcd.print("MODE 3 : ");
