My goal is to set up the NodeMCU with the blynk app so that when the water sensor does not sense water it sends a notification to my phone. I’m new to blynk and I’m not sure how to approach this. The water sensor is currently connected to the A0 pin.
Basically, you just need to monitor the Analog pin (A0), and when it falls below a certain value send notification. You can do this with coding, or by loading the BASIC BLYNK sketch and using EVENTOR.
I suggest you do a little reading of the DOCS, and search a little around the forum. I don’t think anyone is going to write the code for you. Although there may be some code floating around here if you take a look.
If after that you get hung up, post what you have tried, and we will see if we can get you pointed back in the right direction.
I have looked around and I am trying to follow this tutorial: https://www.youtube.com/watch?v=egGs_jSIKbc
How do I find out what type of sensor I have? In the tutorial she has a DHT11. How do I replace the code that has the defined pin?
this will send the value of the sensor to Virtual pin 5.
You could then use Eventor to send a notification when the value passes a certain valve. Although this may lead to repeated notifications if the value bounces above/below this value.
If you send the notification using code, then you will want to have a “notification flag” as to not send repeated notifications when the value drops below the setpoint.
Okay I wrote some code according to some info I found.
Code 1:
Serial.printLn(w);
Blynk.virtualWrite(v5, w);
if(w < 600)(
Blynk.notify("PAWB Alert - Your water bowl is empty!")
In the code the w stands for water. I don’t know if the virtual write is necessary or not. I want to some how incorporate it into this code so I can send a notification to my phone.
Code 2:
char auth[] = "";
char ssid[] = "";
char pass[] = "";
void myTimerEvent()
Blynk.virtualWrite(V5, analogRead(A0) );
As mentioned in my earlier post, we are not going to write the code for you (at least I am not). Search around this forum, and there are a lot of example/code for what you are trying to do (although some are using temp or other things instead of moisture, but basically the same idea). Once you get something put together I will be happy to take a look, and assist if possible.
HERE is a starting point (I am sure there are other things to search that will also lead to results).
If the coding aspect is too much, try using EVENTOR. For example, When V5 is less than 600, send notification.
I would also change the timer interval to like 5 minutes or something as checking every second is probably not necessary.
