BLYNK
NodeMCU v3 esp8266 периодично дисконектится
Всем доброго времени суток!
Возникла проблема. Постоянные дисконекты.
Использую NodeMCU v3 esp8266 c USB разъемом. RGB светодиодную ленту WS2812b.
Смартфон на Android 9.
Библиотека Blynk 0.6.1
Использую сервер Blynk
Использую стандартный пример для NeoPixel
    Follow us:                  http://www.fb.com/blynkapp
                                http://twitter.com/blynk_app
  Control a color gradient on NeoPixel strip using a slider!
  For this example you need NeoPixel library:
    https://github.com/adafruit/Adafruit_NeoPixel
  App project setup:
    Slider widget (0...500) on V1
#include <Adafruit_NeoPixel.h>
char auth[] = "mytoknvjY";
char ssid[] = "myssid";
char pass[] = "mypass";
#define PIN 8
Adafruit_NeoPixel strip = Adafruit_NeoPixel(10, PIN, NEO_GRB + NEO_KHZ800);
// Input a value 0 to 255 to get a color value.
// The colours are a transition r - g - b - back to r.
uint32_t Wheel(byte WheelPos) {
  if (WheelPos < 85) {
    return strip.Color(WheelPos * 3, 255 - WheelPos * 3, 0);
  } else if (WheelPos < 170) {
    WheelPos -= 85;
    return strip.Color(255 - WheelPos * 3, 0, WheelPos * 3);
    WheelPos -= 170;
    return strip.Color(0, WheelPos * 3, 255 - WheelPos * 3);
BLYNK_WRITE(V1)
  int shift = param.asInt();
  for (int i = 0; i < strip.numPixels(); i++)
    strip.setPixelColor(i, Wheel(shift & 255));
    // OR: strip.setPixelColor(i, Wheel(((i * 256 / strip.numPixels()) + shift) & 255));
  strip.show();
  strip.begin();
  strip.show();
    ___  __          __
   / _ )/ /_ _____  / /__
  / _  / / // / _ \/  '_/
 /____/_/\_, /_//_/_/\_\
        /___/ v0.6.1 on NodeMCU
[624] Connecting to blynk-cloud.com:80
[1239] Ready (ping: 253ms).
*⸮⸮⸮⸮Z⸮⸮[46] Connecting to tosyak
[550] Connected to WiFi
[550] IP: 192.168.0.103
[550]
GPIO8 is an illegal pin to use with the NodeMCU.
GPIO8 and the pin marked D8 are not the same thing.
You should read this:
