I’m kind of stuck in my project and request from all you experienced programmers.
I am currently using a Nodemcu V3 and a SKU:SEN0257 water pressure sensor connected to A0.
It works perfectly to see the pressure value through the serial monitor, but i would like to send the value to Blynk. I have setup a value display (V2) and the project connects to the Blynk server, but still no data coming to the value display.
Please assist!
#include <Blynk.h>
char auth[] = "xxxxxxxxxxxxxxxxxxxxxxx";
char ssid[] = "xxxxxxxxxxxxxxxxxxxxxxx";
char pass[] = "xxxxxxxxxxxxxxxxxxxxxx";
const float OffSet = 0.788 ;
float V, P;
Serial.println("/** Water pressure sensor demo **/");
//Connect sensor to Analog 0
V = analogRead(0) * 5.00 / 1024; //Sensor output voltage
P = (V - OffSet) * 400; //Calculate water pressure
Serial.print("Voltage:");
Serial.print(V, 3);
Serial.println("V");
Serial.print(" Pressure:");
Serial.print(P, 1);
Serial.println(" KPa");
Serial.println();
Blynk.virtualWrite(V2, P);
Dear Mr. Knight!
I updated the code and compiled it and it seem to be working but i cannot connect to the blynk server for some mysterious reason.
The wifi doesn’t have a password and i am sure that i wrote the correct SSID.
#include <Blynk.h>
char auth[] = "xxxxxxxxxxxxxxxxx";
char ssid[] = "xxxxxxxxxxxxxxxxx";
char pass[] = "";
float V, P;
Serial.println("/** Water pressure sensor **/");
sensorDataSend();
timer.setInterval(1000L, sensorDataSend);
void sensorDataSend()
Serial.print(V, 3);
Serial.print(P, 1);
Serial.println();
timer.run(); // run timer every second
The following can be seen in the serial monitor:
03:24:19.245 → Voltage:0.752V
03:24:19.245 → Pressure:-14.4 KPa
03:24:19.245 →
03:24:19.292 → Voltage:0.752V
03:24:19.292 → Pressure:-14.4 KPa
03:24:19.292 →
03:24:20.315 → Voltage:0.752V
03:24:20.315 → Pressure:-14.4 KPa
03:24:20.315 →
03:24:21.244 → [30006] Connecting to 0.0.0.0
03:24:24.262 → Voltage:0.752V
03:24:24.262 → Pressure:-14.4 KPa
03:24:24.262 →
03:24:24.305 → Voltage:0.752V
03:24:24.305 → Pressure:-14.4 KPa
03:24:24.305 →
03:24:25.319 → Voltage:0.752V
03:24:25.319 → Pressure:-14.4 KPa
03:24:25.319 →
03:24:26.244 → [35007] Connecting to 0.0.0.0
It seems it was missing from the first sketch too, despite @David_Gronlund saying
I guess that this was a different version of the code?
It can get messy when you’re trying 101 different th8 gs to get something working.
The other thing I noticed is this:
This isn’t normally needed, but if you had to add it in response to a compiler messaging that it couldn’t find Blynk.h then maybe there’s also problem with the way your Blynk library is installed?
Nice project David_Gronlundi have wemos D1 i insert the code , its connect with blynk its fine ,but on V2 i have continuous value 1682.84 .
Its not change . Here is the code .
WeMos D1 R2 ver 2.1 i connect +5 and A0 .
On the value display if I put the pin analogic A0 the value is oscillating or is changing room 140 .
When I blow the value is changed to 160 - + of course.
The D1 R2 has an ADC that allows a maximum input voltage of 3.2v
The sku-sen0257 has an output voltage on the signal pin of between 0.5 and 4.5v
This means that if your sku-sen0257 is outputting anything over 3.2v then it will produce a reading of 1023 from the ADC.
It looks like you need a voltage divider on your analog input to make this sensor work correctly with your board.
