[NodeMCU]Serial.parseInt() stops waorking after a few seconds
I try to use serial to communicate between two boards (NodeMCU and Arduino). Arduino for receiving and processing sensor data, and NodeMCU for sending reading to Blynk. Every second, Serial.println() on Arduino and Serial.parseInt() on NodeMCU. However, the reading received by NodeMCU is normal for only about 5-10 seconds and it jumps to 0. My current solution is that once the reading becomes 0, restart the board. But this is a lame solution.
BTW if I remove all the Blynk element on my NodeMCU board, the reading works perfectly well.
I connected serial port for two boards.
NodeMCU | Arduino
TX | RX
RX | TX
Here is my code:
NodeMCU
char auth[] = "replaced";
char ssid[] = "aa";
char pass[] = "aa";
SimpleTimer uploadtimer;
SimpleTimer sensortimer;
SimpleTimer reconnecttimmer;
int a = -1;
void(* resetFunc) (void) = 0; //declare reset function @ address 0
void uploadTimerEvent()
  if(a>200)
  Blynk.virtualWrite(1, a);
void sensorTimerEvent()
  a = Serial.parseInt();
  Serial.println(a);
  if(a==0) resetFunc();  //call reset
void reconnectBlynk() {
  if (!Blynk.connected()) {
    if(Blynk.connect()) {
      BLYNK_LOG("Reconnected");
      BLYNK_LOG("Not reconnected");
BLYNK_READ(V2)
  Blynk.virtualWrite(V2, millis() / 1000);
  uploadtimer.setInterval(1000L, uploadTimerEvent);
  sensortimer.setInterval(1000L, sensorTimerEvent);
  reconnecttimmer.setInterval(10000, reconnectBlynk);
  if (Blynk.connected()) {
  uploadtimer.run();
  sensortimer.run();
  reconnecttimmer.run();
Arduino
int pin1 = A0;
int pin2 = A1;
int pin3 = A2;
int pinout1 = 7;
  pinMode(pin1, INPUT);
  pinMode(pin2, INPUT);
  pinMode(pin3, INPUT);
  pinMode(pinout1, OUTPUT);
  int a = analogRead(A0);
  int b = analogRead(A1);
  int c = analogRead(A2);
  int avg = (a + b + c) / 3;
  Serial.println(avg);
Serial output for NodeMCU
[57] Connecting to TANJX
[1559] Connected to WiFi
[1559] IP: 192.168.1.9
[1559]
    ___  __          __
   / _ )/ /_ _____  / /__
  / _  / / // / _ \/  '_/
 /____/_/\_, /_//_/_/\_\
        /___/ v0.4.6 on NodeMCU
[5001] Connecting to blynk-cloud.com:8442
[5312] Ready (ping: 3ms).
916
915
914
917
915
914
0
